Using Power Supply Connection as ON/OFF with BOE Board
For a project I'm working on I'd like to mount my BOE development board inside a project enclosure box along with the other electronics. Because the board's power switch would inaccessible, can I leave the board switch in the "on" position and install a switch between my wall adapter power supply and the board's barrel plug connector to turn the device on and off or is this bad for the board? The Stamps in Class texts frequently mention the importance of having all connections in place before operating the power switch but this would be similar to turning the board off by yanking the power.
Dan Toborowski
President
Central Illinois Robotics Club
www.circ.mtco.com
Dan Toborowski
President
www.circ.mtco.com
The line from the "Stamps In Class" is trying to keep people from adding connections while power is on -- which can have disasterous consequences.
