My Propeller Platform Module
On Sat I received my Propeller Platform (PP) board from Gadget Gangster, I got the assembled version. I like the the board a lot, has anybody else purchased one? Jon laid out the board quite nicely, and I like the hefty power supply; now I will not have to worry to much when I power it with 12VDC. Good job Jon. Whoever did the soldering of the board also did a very nice job.
I want to get a couple things clarified-
As I look at P28, and P29 header, that can be used as an I2C buss, correct? What are the limitations, since I only see one resistor?
The power header has VIN,V50,V33, and GND connector. Can I bring in a 5VDC, and GND wire to power up the whole board, or does it just provide a 5VDC source to the header on the other side of the board? I looked at the schematic, and could not figure that one out. The other one is the VIN+GND connection, does the on/off switch still control that circuit? I am not an EE, and never claimed to be one [noparse]:)[/noparse]
Are there any "shields" in the works? I guess maybe a propeller+ram expansion "shield", I think there has been some talk about wanting more cogs, i/o, and memory. Maybe a "shield" would be a nice compact way to go. Just an idea.
Ray
Post Edited (Rsadeika) : 10/26/2009 10:53:17 AM GMT
Ray
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
To answer your questions;
1 - the power switch does control the Vin at the headers - flip off the switch and no Vin at the connector.
2 - I'm pretty sure you can add 5V at the header, but I haven't tried it. Does anyone else know if you can provide a regulated voltage to the output half of a regulator without any problems (if the regulator input isn't connected)?
Currently, there are a few modules;
LCD UI Module
Prototyper Module
A few more are in production;
Mono LCD and Color LCD touchscreen
DMX IO
Arduino Converter
There are also a few designs 'in the wings'
Picaxe 40 / 28
Video IP
@cluso - I can't actually tell if your RamBlade will connect to the Propeller Platform, are the power connections the same?
Gadget Gangster - Share your Electronic Projects
