A Propeller birthday! Ideas?
My birthday is coming up and since I am so into the Propeller I thought that I should ask for Propeller related gifts from everyone. What should I ask for? I am about at the intermediate rank and I have ALMOST every starter kit.
Computers are microcontrolled.
Robots are microcontrolled.
I am microcontrolled.
But you·can·call me micro.
Want to·experiment with the SX or just put together a cool project?
SX Spinning light display·
Want cheap wholesale electronic parts?
Transistor parts wholesale
SD-Card Adapter
some strong servos building your own robot-arm
Say it module
stepper motor
PCB printing Kit
433MHz Tranceiver
Rayman's display
Servos and sensors are good to learn
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
Parallax Inc.
As I always said ... All posible advanced sensors.
Propeller and Propeller boards cost not so much but advanced sensors cost much many and are very useful
( That ones I need but only can dream that I will have ).
Regards
Christoffer J
For every stupid question there is at least one intelligent answer.
Don't guess - ask instead.
If you don't ask you won't know.
If your gonna construct something, make it·as simple as·possible yet as versatile as posible.
Sapieha
Act fast - I'm shipping tomorrow.
Parallax Inc.
Just keep it away from your sister so she doesn't try to dry her hair with it. And set her curls afire.
Sensors will give you lots of fun.
El wire look cool.
Books will help you learn. I recommend something to do with data structures or a high level programing language. If you want to stick with embedded you may find vhdl interesting.
24 bit LCD Breakout Board coming soon. $22.99 has backlight driver and touch sensitive decoder.
If not, ask for one. Right now is the perfect time to get started using one. I had one about your age, and it was excellent. Learned a ton. Fun too!
Chat in real time with other Propellerheads on IRC #propeller @ freenode.net
24 bit LCD Breakout Board coming soon. $21.99 has backlight driver and touch sensitive decoder.
Now that I am on a computer with a keyboard, I will type up a proper response.
ViewPort - This may be over the budget. Rarely do they spend over $100 on my birthday.
SD Card adapter - I have mctrivia's PropMod
Strong servos for a robot arm - Cool!! I've always wanted to build one, but what is a good servo supplyer for this type of project
Say it module - Awesome product, but not economically usefull. If you ever wanted to put a project using it on Gadget Gangster or such, it would be extremilly expensive
Stepper Motor - I don't have experience with one. (even better reason to buy it!)
PCB Printing Kit - Yea! What would you recommend? I've always wanted one....
433Mz Transciever - Wireless technology is something that facinates me, I'll get this for sure.
Raymans display - I have an order for his touchscreen already. Is it worth $100 for the PSM??
Breakout with touch - Yes. This is one for sure, I just hope my dad will order off a forum.....
X - band Motion detector - This is something I know I would have fun with. I am curious: how does it work?
All advanced sensors - I really should, I don't own a single sensor!!
Progamming books - Which ones do you suggest?·I want the Propeller one comming out in febuary, but what non-parallax ones should I get?
Basic Electronics theory books - I don't own one. I do have a componant encyclopedia, but that isn't what you're talking about
A 101 electronics project kit - Have one and finished it when I was 9
Math books - 10th grade geometry is hard enough, and i'm not a fan of math!!
Heat gun - "I'll just loosen up some of these parts..." *woosh* "AHHH!!! It's on fire!!!!"·
Toster oven - Oh! That would be great! Then I can really SMD!!
Scope - I don't have one, and I don't know if it would be worth the money. It's probley like the Demo Board. Once I got it I didn't know how I·went without it!
Books - I have a lot and I need a lot.
Data structures & Problem Solving Using JAVA - I'll look into it.
Thanks for the list so far. Any other suggestions are welcome!!
Thanks agian Ken! I wouldn't be half as far along in my electronics and programming if it hadn't been for you!!
Some of my text books I may recomend:
Technical mathematics with Calculus SI Edition - Paul Calter & David Egerton(Has everything to do with electronics except Z transforms)
Circuit Analysis Theory and Practice - Robbins & Miller
Electronic Devices - Floyd
of these the Math is the most important. The others you can easily find bits and pieces of on google. The data structures text I mentioned before is geared towards Java but it will change the way you think about data and how to manipulate it.
The math punishments you may be experiencing now are laying a foundation for your success. Just hold your breath and do your work - you'll be fine.
Any other ideas?
I ignored calculus when I was at school and then entered into a science that uses little else.
Style and grace : Nil point
The Pragmatic Programmer
Programming Principles and Practice using C++
Java After Hours
Data Structures and Algorithms with C++ (by Weiss)
Digital Design (by Vahid)
Now books like that for Spin might find a ready made market.
Of course none of the books really sound like birthday joy like the EL wire stuff [noparse]:)[/noparse]
I know only BASIC and SPIN so JAVA would be good to add to the list.
