My Propeller Platform Module — Parallax Forums
RsadeikaRsadeika Posts: 3,882
edited 2009-10-26 19:57 in Propeller 1
On Sat I received my Propeller Platform (PP) board from Gadget Gangster, I got the assembled version. I like the the board a lot, has anybody else purchased one? Jon laid out the board quite nicely, and I like the hefty power supply; now I will not have to worry to much when I power it with 12VDC. Good job Jon. Whoever did the soldering of the board also did a very nice job.
I want to get a couple things clarified-
As I look at P28, and P29 header, that can be used as an I2C buss, correct? What are the limitations, since I only see one resistor?
The power header has VIN,V50,V33, and GND connector. Can I bring in a 5VDC, and GND wire to power up the whole board, or does it just provide a 5VDC source to the header on the other side of the board? I looked at the schematic, and could not figure that one out. The other one is the VIN+GND connection, does the on/off switch still control that circuit? I am not an EE, and never claimed to be one [noparse]:)[/noparse]
Are there any "shields" in the works? I guess maybe a propeller+ram expansion "shield", I think there has been some talk about wanting more cogs, i/o, and memory. Maybe a "shield" would be a nice compact way to go. Just an idea.
Ray
Post Edited (Rsadeika) : 10/26/2009 10:53:17 AM GMT
