Debounce problem
Has anyone been able to get this debounce code (obex.parallax.com/objects/489/) to work properly? I'm trying to debounce five buttons on a membrane keypad, but get multiple closures even with a 100 ms delay.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Leon
I have never used a time delay to prevent bounce. I always use an OR to prevent bounce. With the OR scenario, the program will always need to make at least two loops to see the input (button down), and will release after two successful loops without the button pressed. It takes a little more to do it that way, but does free up a cog.
With the OR method....you must program to toggle only when the OR'd input changes to 1, not every time the input is one.
I think you will have more luck with the OR method.
James L
James L
Partner/Designer
Lil Brother SMT Assembly Services
Please note: Due to economic conditions the light at the end of the tunnel will be turned off until further notice. Thanks for your understanding.
That is you have to see the button down 2 out of 3 times through the loop.
I too think the OR loop method is better.
Jack
Jack,
I have done that too, but wanted to get the simple across first, then if there were problems to put the majority loop in.
James L
James L
Partner/Designer
[noparse][[/noparse]Edit] Just a thought: If your debounce timing is 100ms but you accessing the debounced result more frequently than that you could be seeing false positives (from the previous scan). Perhaps what you need to do is clear the result after reading it.
I just added this method to the version on my computer:
Post Edited (JonnyMac) : 10/21/2009 5:36:25 PM GMT
Here's my test code:
con _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 PB0 = %000001 PB1 = %000010 PB2 = %000100 PB3 = %001000 PB4 = %010000 MASK = PB0 | PB1 | PB2 | PB3 | PB4 ACT_HI = 1 ACT_LO = 0 LED0 = 8 LED1 = 9 obj btns : "jm_debounce" debug : "SimpleDebug" var long count pub main | b DirA[noparse][[/noparse]LED0] := %1 DirA[noparse][[/noparse]LED1] := %1 debug.start(9600) Count := 0 btns.init(MASK, 100, ACT_LO) Repeat b := btns.getbits(MASK) btns.clearbits(MASK) case b PB0 : Count++ PB1 : Count-- waitcnt(clkfreq / 10 + cnt) debug.dec(Count) debug.putc($20)I need to stop it repeating if the key is held down, but that should be easy.
Leon
Post Edited (Leon) : 10/21/2009 6:11:56 PM GMT
pub getbuttons(mask) | gbresult gbresult := mask repeat 25 gbresult &= ina waitcnt(clkfreq / 1_000 + cnt) return gbresultAdd ! in front of ina for active-low inputs -- result is still expressed as 1 = button pressed.
pub main | bnew, bprev term.init(30, 115_200) waitcnt(clkfreq / 10 + cnt) term.tx(CLS) repeat bnew := getbuttons(MASK) case bnew PB0 : if (bprev <> PB0) count++ PB1 : if (bprev <> PB1) count-- bprev := bnew waitcnt(clkfreq / 10 + cnt) term.dec(count) term.tx(" ") pub getbuttons(m) | gbresult gbresult := m repeat 25 gbresult &= !ina waitcnt(clkfreq / 1_000 + cnt) return gbresultThe key is to check to see if the new key press is the same as the previous; if yes, don't do anything.
Leon
