Debounce problem — Parallax Forums
Debounce problem
LeonLeon Posts: 7,620
edited 2009-10-21 20:39 in Propeller 1
Has anyone been able to get this debounce code (obex.parallax.com/objects/489/) to work properly? I'm trying to debounce five buttons on a membrane keypad, but get multiple closures even with a 100 ms delay.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
  • James LongJames Long Posts: 1,181
    edited 2009-10-21 15:35
    Leon,
    I have never used a time delay to prevent bounce. I always use an OR to prevent bounce. With the OR scenario, the program will always need to make at least two loops to see the input (button down), and will release after two successful loops without the button pressed. It takes a little more to do it that way, but does free up a cog.
    With the OR method....you must program to toggle only when the OR'd input changes to 1, not every time the input is one.
    I think you will have more luck with the OR method.
    James L
    James L
    Partner/Designer
    Lil Brother SMT Assembly Services
    Please note: Due to economic conditions the light at the end of the tunnel will be turned off until further notice. Thanks for your understanding.
  • JackBakJackBak Posts: 45
    edited 2009-10-21 16:25
    For some nasty switch bounce environments I've been known to take James' OR loop and change it to a majority voting loop.
    That is you have to see the button down 2 out of 3 times through the loop.
    I too think the OR loop method is better.
    Jack
    edited 2009-10-21 16:38
    JackBak said...
    Jack
    Jack,
    I have done that too, but wanted to get the simple across first, then if there were problems to put the majority loop in.
    James L
    James L
    Partner/Designer
  • JonnyMacJonnyMac Posts: 9,797
    edited 2009-10-21 17:23
    @Leon: That's a dirt-simple object and I'm surprised (and disappointed) that you're having trouble. Can you post you code so I can see it in context? I tested the object pretty thoroughly but, as ever, reserve the right to be human and make mistakes. My programs work fine -- I'd like to see your code and if it reveals an issue with my debounce object.
    [noparse][[/noparse]Edit] Just a thought: If your debounce timing is 100ms but you accessing the debounced result more frequently than that you could be seeing false positives (from the previous scan). Perhaps what you need to do is clear the result after reading it.
    I just added this method to the version on my computer:
    pub clearbits(mask)
    '' Clears bits from previous scan
    '' -- uses mask to select desired bit(s)
      dbBits &= !mask
    Post Edited (JonnyMac) : 10/21/2009 5:36:25 PM GMT
  • LeonLeon Posts: 7,620
    edited 2009-10-21 17:53
    Thanks, JM. Clearing those bits fixed it! I still get some bounce with 20 ms, but it's OK with 50 ms.
    Here's my test code:
    con
      _clkmode = xtal1 + pll16x
      _xinfreq = 5_000_000
      PB0   = %000001
      PB1   = %000010
      PB2   = %000100
      PB3   = %001000
      PB4   = %010000
      MASK = PB0 | PB1 | PB2 | PB3 | PB4
      ACT_HI   = 1
      ACT_LO   = 0
      LED0  = 8
      LED1  = 9
    obj
      btns          : "jm_debounce"
      debug         : "SimpleDebug"
    var
      long count
    pub main | b
      DirA[noparse][[/noparse]LED0]                    := %1
      DirA[noparse][[/noparse]LED1]                    := %1
      debug.start(9600)
      Count := 0
      btns.init(MASK, 100, ACT_LO)
      Repeat
        b := btns.getbits(MASK)
        btns.clearbits(MASK)
        case b
          PB0 : Count++
          PB1 : Count--
        waitcnt(clkfreq / 10 + cnt)
        debug.dec(Count)
        debug.putc($20)
    I need to stop it repeating if the key is held down, but that should be easy.
    Leon
    Post Edited (Leon) : 10/21/2009 6:11:56 PM GMT
    edited 2009-10-21 18:13
    Glad things are better, but I'd still like to see how you're getting bounce. The trouble, perhaps, is that the debounce window is not synchronized with anything else. If you don't need "background" debouncing you could always do the process in a simple loop. Assuming active-high inputs, something like this should work:
    pub getbuttons(mask) | gbresult
      gbresult := mask
      repeat 25
        gbresult &= ina
        waitcnt(clkfreq / 1_000 + cnt)
      return gbresult
    Add ! in front of ina for active-low inputs -- result is still expressed as 1 = button pressed.
    edited 2009-10-21 18:49
    Okay, if you want to see a stream of numbers on the terminal, but only one inc/dec action per button press (and hold), you can do it like this:
    pub main | bnew, bprev
      term.init(30, 115_200)
      term.tx(CLS)
      repeat
        bnew := getbuttons(MASK)
        case bnew
          PB0 : if (bprev <> PB0)
                  count++
          PB1 : if (bprev <> PB1)
                  count--
        bprev := bnew
        term.dec(count)
        term.tx(" ")
    pub getbuttons(m) | gbresult
      gbresult := m
      repeat 25
        gbresult &= !ina
      return gbresult
    The key is to check to see if the new key press is the same as the previous; if yes, don't do anything.
    edited 2009-10-21 18:52
    Leon, yes you need quite a hefty time for each press to settle, meaning both when pressed there is debounce, and when released there is debounce. That is why the PC keyboard typically used 15 keys/second repeat. You need to restart your debounce time each time you get a false transient. (I didnt look at any code above)
    · Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)
    · Search the Propeller forums·(uses advanced Google search)
    Thanks, JM; that does just what we need.
    Leon
