Basic stamp IDE
Tumbler
Hi,
I'm using a bs2pe with the RUN command.
After reading this in the help, i'm always frustrated when i have to update the var declarations in each program file.
my suggestion is to add an include to·the var declaration file.
Would be very nice to work with and prevent the, like dev/null says:·things will go bananas
(http://forums.parallax.com/showthread.php?p=849332...)
I don't know if parallax is updating the IDE for the stamp butHelp file said...
What Happens To I/O Pins And RAM When Using RUN?
The I/O pins retain their current state (directions and output latches) and all Variable and Scratchpad RAM locations retain their current data during a transition between programs with the RUN command. If sharing data between programs within Variable RAM, make sure to keep similar variable declarations (defined in the same order) in all programs so that the variables align themselves on the proper word, byte, nibble and bit boundaries across programs. The following programs illustrate what happens with mismatched variable declarations:
HTH,
--Rich
