max propagation delay — Parallax Forums
mctriviamctrivia Posts: 3,772
edited 2009-10-20 13:15 in General Discussion
I have a parallel bus with the propagation delay difference between shortest trace and longest is 71pS(21mm)
Is there any good rule of thumb for the maximum usable frequency?
I am sure at 100MHz it would be fine being the delay is 142th of the signal frequency but curious what would the max recommended be.
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
Post Edited (mctrivia) : 10/20/2009 1:03:48 PM GMT
    edited 2009-10-20 04:47
    mctrivia,
    "Is there any good rule of thumb for the maximum usable frequency?" - In this case, you can't go any faster than your longest delay. That's going to be your weakest link. "Every body else" either needs to come down to meet the slowest propagation delay by purposefully introducing delays to the faster lines, or you need to make sure that the data doesn't become valid until the slowest propagation has transitioned.
    Beau Schwabe
    IC Layout Engineer
  • PhilldapillPhilldapill Posts: 1,283
    edited 2009-10-20 04:53
    Wow. It's these sort of threads that make me step back and look at the big tech picture... We've progressed so far in the last 30 years that technology is at the point of someone like mctrivia whining about a 71pS propogation delay. Boo hoo mctrivia! Jeez, give it a second... I mean, your signals are going as fast as light! That's amazing! LOL
    Beau Schwabe (Parallax) said...
    In this case, you can't go any faster than your longest delay. Every body else" either needs to come down to meet the slowest propagation delay by purposefully introducing delays to the faster lines, or you need to make sure that the data doesn't become valid until the slowest propagation has transitioned.
    I agree completely.
    I was thinking I do not need to go through the hoops of adding intentional delay to the shortest paths? Running IDE signal bus of only 100 to 133MHz my shortest signal path has a propagation delay of 36pS and my longest of 106pS.
    133MHz signal has a bit length of 7.5nS more then 100 times the delay imparted by my traces not being the same length so I am sure I am fine here. I know as long as my delay does not exceed the bit speed in theory it could work but was wondering about safe practices what would be the max?
    1/2, 1/4, 1/10 the bit speed. What is safe?
