fordata LCD display with propeller? — Parallax Forums
CrosswindsCrosswinds Posts: 182
edited 2009-10-19 16:43 in Propeller 1
Hello!
Ive found an Fordata LCD graphical display, that i have had for some time. Used for an old PC project.
Thought it would be fun to see if i can run it with the propeller, but the only information i have is the sheet i have attached to this thread.
Really dont know where to start with this [noparse]:)[/noparse] hope someone can help me!
·LCDname: fordata fdcg12864b
Thank you!
lcd.pdf 364.7K
  • RaymanRayman Posts: 16,385
    The 5 V I/O is the problem... It could be that it will recognize 3.3 V as logic 1 and in that case it will work... But, the datasheet for the controller says 0.7*VDD, which is 3.5 V. So, there's a good chance it won't work...
    BTW: I'm working on a display very similar to that one, but runs off of 3.3 V...
    My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
