How2? Touch Sensitive Panels ala 'Star Trek' - creative solutions — Parallax Forums
CounterRotatingPropsCounterRotatingProps Posts: 1,132
edited 2009-10-28 09:28 in General Discussion
Picture the control panels of the later Star Trek series...
I'd like to make something that looks similar, without using a 'touch screen' monitor.
1. Take a 1/4 inch Lexan/plexiglass sheet - WxH are arbitrary
2. Mask off the underside with the design that would show through
3. Spray the back/underside of it flat or gloss black.
4. Remove mask.
5. Mask again where needed...
·· 6. Spray with transparent color...
·· 7. Repeat step 5-6 as needed to get all colors.
8. Backlight with LED assembly.
The part I don't understand - or if this is even·possible:
A. Can CapSens material(*) be made translucent/transparent?
B.·Can it be put underneath the plexiglas and still·work through·such a thick piece of material?
*) What would the·CapSense sensor material·be made of?
Thanks for your insights and suggestions!
- Howard
Post Edited (CounterRotatingProps) : 10/28/2009 2:23:24 PM GMT
    edited 2009-10-16 18:30
    Whoops! This somehow ended up in the wrong thread first...
    LCARS – Library Computer Access & Retrieval System
    I tried to use Flash once to make a website built around this type of interface. I failed…probably just as well. Anyway, touch sensors such as those that are used in iPods are very common now and there are several IC manufacturers that make chips that handle multiple channels and arrays to implement such a system. Many have sensitivity adjustments and filters for situations such as you describe (Freescale MPR121).
    I still think a touch-screen could realize this better, but I am not clear on what you’re planning so that is a matter of perspective. You can check into that IC or ones made by Quantum Research Group (we used to carry the QT113). I hope this helps. Take care.
    Chris Savage
    Parallax Engineering
    50 72 6F 6A 65 63 74 20 53 69 74 65
  • CounterRotatingPropsCounterRotatingProps Posts: 1,132
    edited 2009-10-16 20:05
    Thanks Chris,
    Yes, there are quite a few companies making such chips. I appreciate the specific suggestions.
    I'd like to be able to make odd-sized and larger panels. So, touch screens wouldn't work.
    I'll dig in the datasheets and see if there is a penetration limit.
    The "electrodes" seem to be a simple conductive material ... I wonder if there's a clear, electrically conductive film, plastic or foil that would work?
    - H
  • Beau SchwabeBeau Schwabe Posts: 6,574
    edited 2009-10-16 20:25
    CounterRotatingProps,
    This company might be of interest, their SAW (Surface Acoustic Wave) Panels might be of interest.
    www.densitron.com/Displays/Content.aspx?id=2190
    The technology of SAW sensing is such that you could apply this to just about any surface.
    www.touchuserinterface.com/2009/08/acoustic-touch-sensing.html
    ...And yes, the Propeller could probably do something very much like this using acoustics, but to my knowledge I haven't seen anyone apply this.
    Beau Schwabe
    IC Layout Engineer
    edited 2009-10-16 21:13
    Thanks Beau,
    You guys are the best!
    > the Propeller could probably do something like this ...
    and you seem to be mind readers too [noparse]:)[/noparse])
    The SAW Stuff is very interesting!
    On the touch sense side, I came across this a while back (not sure if it can do the job, but it's cheap) :
    PSoC3 "FirstTouch" starter kit
    http://www.cypress.com/?rID=38235
    l
    edited 2009-10-18 03:55
    i have a quantum development kit somewhere for touch sensitive ic.
    you can make touch sensitive panel through as much as 1/2" glass though the thiner the easier it is to read.
    the bad part is you need to make a pcb the size of your screen for the cap sens traces. for back lighting though you can use reverse mount surface mount leds and drill wholes through the pcb. you can also get clear pcbs made but i have not found a suplier yet and the coper will still be visible.
    propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
    Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
    Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
  • waltcwaltc Posts: 158
    edited 2009-10-18 04:24
    Freescale has a $30 Coldfire eval board that has the touch sensors and a 3 axis acceleration sensor built in.
    Links:
    8 Pad touch sensor controller
    http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=MPR084
    8 position rotary controller
    http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=MPR083
    http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=MMA7260QT
    Badgeboard
    http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=JMBADGE
    Schematic for BadgeBoard - also shows how the sensor chips are interfaced.
    http://www.freescale.com/files/JMBADGESCHC.pdf?fpsp=1
    edited 2009-10-18 06:21
    RE: your questions:
    A) Capsense pads must be copper (well conductive metal...) so the translucent question is a no.
    B) Yes, capsense will work through 1/4" plexiglass. The trick is properly matching your circuit to the dielectric constant of the material. Basically the thicker the material or lower the constant, the larger the pad needs to be.
    I have the CY3270 First Touch kit for the Cypress PSoC. It has a Capsense Slider on it and it is really easy to see how to utilize capsense pads using that kit. It is $33 at Digikey. (was $20 when I got it a couple years ago)
    Cypress PSoC chips can do CapSense through various thicknesses of material. I know of a couple designs that use a dime sized pad and work excellent through 1/4" acrylic. I have also seen various designs using Qtouch parts. One consists of pads about 2"x1.5" and it mates behind a 0.150" thick piece of polycarbonate. The Qtouch parts are a lot easier to use because once you determine the variables (pad sizes, part values) you just build it and it will more than likely work. With the PSoC parts, you have to program the specifics in addition to determining values and pad sizes. The PSoC Designer IDE is reasonably easy to use if you have previous C experience to understand what the visual interface is creating. The difference with the PSoC however, is that you can throw down a circuit and modify your coding to make it work even if the circuit is less than ideal. This may be the best choice because you could use discrete wiring to foil pads on your display and use the PSoC feedback programs to see how the circuits react to fine tune your capsense settings. This would require a lot of trial and error with wiring design and programming though.
    Some things to look at:
    Capacitance Sensing - Layout Guidelines for PSoC CapSense - AN2292
    www.cypress.com/?rID=2887
    Quick Layout guidelines
    www.cypress.com/?rID=34564
    CapSense™ Best Practices - AN2394
    www.cypress.com/?rID=2883
    Attached is a document from QTouch about secrets for a successful design. I have one of the older QT240 demo boards that I bought for a project because it was easier to spend $19 on a demo board then it was to design/build my own.
    You can also use springs to have a larger gap between the PCB and the overlay material. The second PDF attached has details on how that is done.
    Andrew Williams
    WBA Consulting
    Special Olympics Polar Bear Plunge, Mar 20, 2010
    edited 2009-10-18 19:34
    Mesh aluminum screen might be okay for the touch areas, to let light through. The area has to be at least several times the material thickness.
    There are several ways that these things work, one being charge transfer. (In Quantum parts such as the QT113, the QT stands for charge=Q Transfer). The plate is first charged up to a certain voltage, say 3.3 volts by connecting it to (say) a Prop pin set high. The pin is then set as an input, and then an analog switch is closed that connects the plate to another capacitor that is connected to a comparator input, which might be a Prop pin. The capacitance of the plate is small, so with one cycle of charge transfer, the voltage at the comparator input does not rise by much, so it takes many cycles of charge and transfer to reach the comparator trip point, but it takes many fewer when someone is touching the plate. I'm just saying you could experiment on your own with simple components without getting into a fancy development technology. The simple single plate configuration takes 3 prop pins and an analog switch or fet. That is not to say that there are not subtleties to deal with. Fancy sequencing of analog switches can deal with differential capacitance and multiple plates. Narrow charge transfer pulses can deal with water films and contamination. Digital filters can deal with gradual drift. etc., what fun! I have made these using the SX, which is good for fast switching sequences.
    Tracy Allen
    www.emesystems.com
    edited 2009-10-18 22:54
    Matt, Walt, Andrew, Tracy,
    thanks much for the detailed guidance - I really appreciate that. Looks like this is not so simple after all !
    Very interesting that there isn't a clear/translucent conductor material of some kind - or is there some high-tech stuff that costs too much? I've been mucking around on the net looking, but no luck. This surprises me actually. One idea: I wonder how much aluminum or brass/bronze powder (c.a. 500 mesh) would be needed in an acrylic or epoxy pour to get the balance between conductivity and clarity ... probably would end up looking smoky ... interesting problem.
    - H
    edited 2009-10-18 23:03
    Howard,
    I think a low-tech bag or sandwich of clear water would work fine. Especially if you increase the conductivity a little bit with something like KOH. The electrical contact for that area would need to be only on the edge. There might also be a suitable gel.
    Tracy Allen
    www.emesystems.com
  • T ChapT Chap Posts: 4,260
    edited 2009-10-18 23:27
    Sure there is a clear. Get ITO coated film. Use double faced adhesive to fasten the acrylic to it. Polycarbonate is better, find an AR version (abrasive resistant). I can give you a vendor if you can't find one. Attach a wire to the ITO film with conductive glue. Then to the IC. Works like metal.
    edited 2009-10-19 20:28
    @Todd - If indium is $1 to $5 per ounce, does that mean ITO (Indium-Tin-Oxide) films are expensive?
    Please do post a supplier or two when you get a second ... I hunted for a while but didn't come up with anything realistic.
    Interesting ... while searching, thin film solar cell's came up (TCO's = transparent conductive oxide).
    @Tracy - do you mean one of those anti-static bag's that our e-goodies come in?
    DOH ! I didn't think about the fact that they would *have to be* conductive to drain the static... one man's trash is another's treasure, eh? [noparse]:)[/noparse])
    edited 2009-10-20 01:23
    Emergency space blankets (the really compact thin kind) are alumiinized polyester that do have a pretty low electrical resistance and do let some light through. But not much. I think anti-static silver bags are probably not conductive enough.
    I was actually thinking of the water being the conductor, or even water that has been gelled stiff with something like polyacrylamide. It could even have food coloring added to make the colors. I just don't know how you would hold that on the bottom of the table. It would have to be some kind of sandwich, but the gelling could help.
    Tracy Allen
    www.emesystems.com
    edited 2009-10-20 01:31
    I think I bought a roll of 4' wide by 8' long of ITO coated file a few years ago for around $100, I can't remember exactly but that is close. I have it in storage so I will try to get by there and get the manufacturer.
    edited 2009-10-20 13:22
    does it really have to be transparent?
    if you use reverse mount leds on a pcb you only need a small hole for the light to transmit through. Or you could mount leds into the plexiglass from the sides like some LCD screens and let it reflect off your pcb and the surface of the plexiglass. will make a decent defused lighting.
    edited 2009-10-20 15:26
    @Tracy - I like your out-of-the-box thinking. The water way might be workable, but I'd have to experiment with the polyacrylamide... if the amines in it are neutral then it might work, otherwise it might be reactive with some of the materials I'm trying. I've had amines eat into things plastic/resin before. Sometimes it takes months for the degredation to show up however (nothing like having the gelled water ooze out --- yikes! [noparse]:)[/noparse]. Yes, the Space Blanket would indeed block too much, but it's a funny idea anyway... it could be used in some interesting ways for artsy projects!
    @Todd - that is a very reasonable price for such a large roll. No hurry, when you get a chance to dig out the info, that'll be great.
    @Matt - thanks for clarifying the approach. Both ways (rev. LED & side mount) would work for certain parts of the display, but the bulk of it needs to be really clear. The side mount LEDs are nice for certain things.
    I also have a fun trick using cheapo fiber optics... sort of obvious: just channel the light where you need it. Hot glue or epoxy the firbers along the masked out (dark) areas, terminate them under or even drill in at the desired display area. The other ends come together in the LED matrix, which can be tightly spaced. I use a second perf board laid on the top of the LED matrix... the fibers poke into and slightly through the holes, aimed at its specific LED. (Oh, I should just make a .jpg... would be easier to see.)
    There are several reasons why I'd like fully clear - the main one is being able to put a cheapo LCD just underneath the main panel (flush), but have the panel 'touchable' ... a cheap(?) way to make a touchscreen out of one that isn't. But more, integrated into a larger touchable panel.
    Thanks again for your suggestions, guys - please keep them coming !
    - Howard
    edited 2009-10-20 17:31
    http://www.sheldahl.com/
    I am pretty sure this was the company. They sell the ITO film in a roll or maybe cut lengths.
    edited 2009-10-20 22:43
    Thanks Todd - am looking into them. - H
    edited 2009-10-20 23:45
    you can buy touch screen films that go overtop of lcd. why not use one of these?
    edited 2009-10-21 01:51
    Because the LCD touchscreen films measure exactly where you touch trough resistance, makeing them more complicated and expensive. A 7 inch touchscreen costs up to 200 dollers. Just a touch sensitive chip like the one Parallax sells would be better.
    Computers are microcontrolled.
    Robots are microcontrolled.
    I am microcontrolled.
    But you·can·call me micro.
    Want to·experiment with the SX or just put together a cool project?
    SX Spinning light display·
    Want cheap wholesale electronic parts?
    Transistor parts wholesale
    edited 2009-10-21 13:03
    not sure where you are figuring your prices.
    http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=BER281-ND
    21" touch screen film for $94
    that and a TSC2003 will give you a large transparent touchable surface.
    edited 2009-10-21 15:32
    Matt,
    If I understand the cover and chip at quick glance, it looks like resistive /pressure sensitive.
    I need the 'sensor' material to be underneath then plexiglass/or normal glass.
    still, thanks for the suggestion.
    - H
    edited 2009-10-21 16:29
    with this method the sense material does have to be on top. It is the only true clear method I know of.
    Capacitance sensors can go behind but trying to build capacitive sensors out of some of the suggested clear materials would probably be very difficult.
    another method i have seen used is an array of infared transmitters on bottom and left side and infared receivers on top and right side. where the signal breaks gives you finger location.
    edited 2009-10-21 19:58
    I wonder about 3M conductive EMI tape. It consists of conductive fibers in a carrier adhesive like acrylic,. It is not totally opaque, not totally clear.
    The metal layer in the resistive touch screen must be very thin to be semitransparent with high and stable resistivity. Is it aluminum, or some other metal? I tried measuring on the surface of a static shielding bag, but either my ohmmeter does not have a high enough scale, or the metal is not actually on the surface.
    It is interesting how conductive properties are associated with opacity, the imaginary part of the light scattering parameter for metals or carbon. Ionic conductivity requires some kind of liquid or gel medium.
    Tracy Allen
    www.emesystems.com
    edited 2009-10-21 21:41
    Tracy Allen> tried measuring on the surface of a static shielding bag, but either my ohmmeter does not have a high enough scale,
    I had to chuckle reading this, Tracy, having tried *exactly* the same thing. Zilch! [noparse]:)[/noparse])
    Seem's like these bags might still work for the capacitive version --- assuming we can *find* the metal to hook onto.
    Guess that's why we can't have windows made out of aluminum?
    The SAW (surface acoustic wave) method is looking more and more attractive. --- or maybe a combination of IR and SAW... and I thought this would be simple [noparse]:)[/noparse]
    edited 2009-10-22 00:30
    i found my e6248 eval board:
    http://parts.digikey.co.uk/1/1/449435-board-eval-qt60248-as-qmatrix-e6248.html
    edited 2009-10-23 05:31
    CounterRotatingProps said...
    I recall reading about clear aluminium somewhere...
    edited 2009-10-23 13:37
    1986 Movie - Star Trek IV: The Voyage Home
    edited 2009-10-26 01:57
    I realized that it might be possible to use the EL sheets to light up and READ a touch panel.
    the concept is that LEDS have a falloff rate due to the photo electric effect, so I propose that a touch panel be made using el-sheets and the propeller.
    The capacitive nature of the el-sheet, el-tape or el-strips might just allow us to use them as both light emission and capacitive detection of the finger.
    I don't have any el-sheets but I have el-wire, but don't have a scope. The only way i can test it, is by programming a prop.
    I would just rather order some el-sheet and test that.
    electroluminescence-inc.com/ELsheets.htm
    mctrivia said...
    ahh yesthats right...,although with todays femtosecond lasers, transparent aluminium is not so "star trek"
    TERMS OF USE: MIT License
    "Permission is hereby granted, free of charge, to any pers...........................
    ..............................OMITTED FOR FORUM...............................................
    .................. OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. "
    The dsp/fpga king is dead, long live the prop.
    Post Edited (Clock Loop) : 10/26/2009 3:57:40 AM GMT
    edited 2009-10-26 03:28
    Heres a link to a better cut-able material.
    Here is el-FLATLIGHT
    www.e-lite.com/flatlite.htm
    If this works, one could make a LCARS panel, using only this el material, a propeller, and a speaker. (plus High Voltage interface circuit)
    The problem is with casting shadows over buttons that you didn't mean to push. (if you try led method)
    If the el material can be used like a touch capacitor, (it does run at 100+ volts ac around 1khz) (almost no current though)
    With that kind of voltage running under a thin piece of plastic, is it possible to detect a persons finger using the capacitive nature of the el sheets?
    Because its not just a LED like material, but its also a huge flat sheet of sudeo metal (aka semiconductor)
    Wish I had some spare cash to test this.
    Why yes, yes I would like a LCARS glowing touch panel, propeller powered, that even has the beep when buttons are pressed. And affordable also.
    Com it up to your pc, and program keyboard shortcuts.
    Bye bye keyboard.
    HELLO LCARS.
    I think this method meets all required conditions to create what you guys want.
    This idea was inspired by my own experience with EL-wire and using LEDS as touch sensors.
    I realized that the el-materials are ideal for this application.
    SHAPE LIMITATIONS OF FLATLIGHT.
    www.e-lite.com/PDFs/FB_SHAPECONSIDERATIONS_ELITE_E1.pdf
    Post Edited (Clock Loop) : 10/26/2009 5:36:17 AM GMT
