Where to Start? Boe-Bot or What's a Micrcontroller
I understand that both of these kits are great starting points for moving on to further projects using BASIC Stamp. As a high school teacher i have the option of using either for a third level pre-engineering course. My goal in using this curriculum in my class is to introduce my students to electronics and programming. It would be easier for me to use the Boe-Bot kits in terms of what i am already in possession of but can buy the necessary components to move forward with "What's a Microcontroller" if it would better serve my purposes. Thoughts? Feedback? Your help is most appreciated.
Mike is correct in saying that the Boe-Bot Kit has most of the parts you need for the exercises in What's a Microcontroller. In fact, you can do 26 of 44 activities that are included in the book! If you and the students do this, you will have picked up most of the important concepts that will enrich Robotics with the Boe-Bot (which is best to do after What's a Microcontroller).
Below is a list of the What's a Microcontroller activities that can be completed with Robotics with the Boe-Bot parts:
Chapter 1, Activity 1 through 7
Chapter 2, Activity 1 through 4
Chapter 3, Activity 1 through 4
Chapter 4, none
Chapter 5, none
Chapter 6, none
Chapter 7, Activity 1 through 3
Chapter 8, Activity 1 through 5
Chapter 9, none
Chapter 10, Activity 1 through 4
I hope this helps!
Jessica
Jessica Uelmen
Education Department
Tia'Shar Manetheren
The question was about high school kids and a 3rd level introductory course for "pre-engineering" which could certainly include robotics. You didn't say what ages or level of schooling you're dealing with and, if you're teaching HVAC, that's a different audience. You would be teaching about motor control and environmental monitoring (temperature and humidity), feedback systems, and status displays. "What's a Microcontroller?" would be a better choice.
