7" Color LCD
Would any of you guys be interested in a 7" color LCD with an 8 bit interface. We had Ampire design us one
for the Propeller chip with the following specifications and it is available from there distributors.
12 line direct propeller interface - 8 data lines + RD\, WR\, CS\ and Register select.
480 x 234 resolution with 65K or 256K colors.
65K color mode requires 2 bytes per pixel and 256K mode requires 3 bytes.
Four wire resistive touch screen.
5 volt display with 3.3v logic interface for direct drive from the Propeller Processor.
White led backlight
Enclosed is the link to the specification
http://www.gamma.spb.ru/download/AM-480234G1TMQW-TB0.pdf
Russ
White led backlight
Russ
The resolution is a bit low @ 480x234
I have seen similar ones with 800x480 resolution
what sort of cost are we talking of ?
is the controller chip an ILI9328 or similar ?
1. Quotation for 7” display with touch panel
· P/N: AM-480234G1TMQW-TB0
· Samples (1-10 units): $135
· 11-50: $110
· 51-100: $105
· 101-200: $104
· 201-500: $98
· 501-1,000:$96
2. Lead-time: 6-12 weeks
Russ
My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
Russ
I'd have to get back to you on quantity pricing. Optional RS232 touch panel for about $50+s/h in sample quantities, same lead time.
I also have 5" 640x480 with VGA interface for about $120+s/h, optional touch panel about $50+s/h.
VGA can be generated with as little as 3 pins (B/W), 5 pins (8 color), 8 pins (64 color); and my Morpheus board can generate 256 colors (10 pins) and has 512KB memory on board with a full expansion bus.
Please use mikronauts _at_ gmail _dot_ com to contact me off-forum, my PM is almost totally full
Morpheus & Mem+dual Prop SBC w/ 512KB kit $119.95, 2MB memory IO board kit $89.95, both kits $189.95
www.mikronauts.com - my site 6.250MHz custom Crystals for running Propellers at 100MHz
Las - Large model assembler for the Propeller Largos - a feature full nano operating system for the Propeller
is pretty quick. We are also looking for a good Graphics Processor Unit (GPU) for the 800 x 480 display.
http://www.newhavendisplay.com/app_notes/FSA506.pdf
Bill,
Thanks for the info but we need either an 8 or 16 bit interface.
Russ
the 800x480 I was comparing is $90 for 1 off
Quantity: 10+ 100+
Price: $80.15USD $71.96USD
check it out
http://www.thaieasyelec.net/index.php/display-module/tft-with-tp/7-inch-tft-touch-screen-display/p_11.html
mike
http://www.thaieasyelec.net/index.php/display-module/breakout-board/breakout-board-2-8-inch-qvga-tft-lcd-with-touch-screen/p_3.html
I bet if you contact them, they would design what they call a breakout board with a suitable controller.
sparkfun buy from them
That is a nice display and is almost exactly the same size as ours. They just finished the mold for our case in China
and it is too late to change the display cutout size & bezel.
Too bad they don't offer it with a controller, we really don't want to fool around with adapter boards.
Russ
