7" Color LCD — Parallax Forums
7" Color LCD
BigFootBigFoot Posts: 259
edited 2009-10-15 21:08 in Propeller 1
Would any of you guys be interested in a 7" color LCD with an 8 bit interface. We had Ampire design us one
for the Propeller chip with the following specifications and it is available from there distributors.
12 line direct propeller interface - 8 data lines + RD\, WR\, CS\ and Register select.
480 x 234 resolution with 65K or 256K colors.
65K color mode requires 2 bytes per pixel and 256K mode requires 3 bytes.
Four wire resistive touch screen.
5 volt display with 3.3v logic interface for direct drive from the Propeller Processor.
White led backlight
Enclosed is the link to the specification
http://www.gamma.spb.ru/download/AM-480234G1TMQW-TB0.pdf
Russ
  • mparkmpark Posts: 1,326
    edited 2009-10-15 17:02
    Depends on the price, but yes, I'd be interested.
  • mikestefoymikestefoy Posts: 84
    edited 2009-10-15 17:09
    I would be interested in a 7"lcd with touchscreen
    The resolution is a bit low @ 480x234
    I have seen similar ones with 800x480 resolution
    what sort of cost are we talking of ?
    is the controller chip an ILI9328 or similar ?
  • BigFootBigFoot Posts: 259
    edited 2009-10-15 17:25
    Here are the prices for this display. If you do not need the touch screen subtract about $15.
    1. Quotation for 7” display with touch panel
    · P/N: AM-480234G1TMQW-TB0
    · Samples (1-10 units): $135
    · 11-50: $110
    · 51-100: $105
    · 101-200: $104
    · 201-500: $98
    · 501-1,000:$96
    2. Lead-time: 6-12 weeks
    Russ
  • RaymanRayman Posts: 15,967
    edited 2009-10-15 17:26
    Sounds pretty good! The 8-bit interface is nice for pin-starved Prop1...
    edited 2009-10-15 17:28
    We are also looking for an 800 x 480 display with an 8 bit interface, any of you guys know a good one to look at ?
    Russ
    edited 2009-10-15 17:47
    I can supply 7" 800x480 with a VGA interface, about $140USD+s/h for samples, 4-5 week lead time.
    I'd have to get back to you on quantity pricing. Optional RS232 touch panel for about $50+s/h in sample quantities, same lead time.
    I also have 5" 640x480 with VGA interface for about $120+s/h, optional touch panel about $50+s/h.
    VGA can be generated with as little as 3 pins (B/W), 5 pins (8 color), 8 pins (64 color); and my Morpheus board can generate 256 colors (10 pins) and has 512KB memory on board with a full expansion bus.
    BigFoot said...
    Russ
    Please use mikronauts _at_ gmail _dot_ com to contact me off-forum, my PM is almost totally full
    Morpheus & Mem+dual Prop SBC w/ 512KB kit $119.95, 2MB memory IO board kit $89.95, both kits $189.95
    www.mikronauts.com - my site 6.250MHz custom Crystals for running Propellers at 100MHz
    Las - Large model assembler for the Propeller Largos - a feature full nano operating system for the Propeller
    edited 2009-10-15 18:00
    The display is controlled by a FSA506 controller. We wrote all the code in assembly and the display
    is pretty quick. We are also looking for a good Graphics Processor Unit (GPU) for the 800 x 480 display.
    http://www.newhavendisplay.com/app_notes/FSA506.pdf
    Bill,
    Thanks for the info but we need either an 8 or 16 bit interface.
    Russ
    edited 2009-10-15 18:04
    no thanks, much much too expensive.
    the 800x480 I was comparing is $90 for 1 off
    Quantity: 10+ 100+
    Price: $80.15USD $71.96USD
    check it out
    http://www.thaieasyelec.net/index.php/display-module/tft-with-tp/7-inch-tft-touch-screen-display/p_11.html
    mike
    edited 2009-10-15 18:05
    forgot to say, the one i am considering doesnt have a controller
    edited 2009-10-15 18:09
    I have one of Thaieasy's 2.8" lcd, and I am driving it with a PIC18F4580.
    http://www.thaieasyelec.net/index.php/display-module/breakout-board/breakout-board-2-8-inch-qvga-tft-lcd-with-touch-screen/p_3.html
    I bet if you contact them, they would design what they call a breakout board with a suitable controller.
    sparkfun buy from them
    edited 2009-10-15 18:12
    that makes a huge difference; also there is the matter of shipping and importing from thailand - plus a small profit.
    mikestefoy said...
    Mike,
    That is a nice display and is almost exactly the same size as ours. They just finished the mold for our case in China
    and it is too late to change the display cutout size & bezel.
    Too bad they don't offer it with a controller, we really don't want to fool around with adapter boards.
    Russ
