RamBlade: Prop+SRAM+microSD addon to run ZiCog/CPM/PropDos/Catalina, etc. SBC s
Cluso99
Project re-specified... please see...
http://forums.parallax.com/showthread.php?p=849265
The RamBlade is almost ready. Please ignore the previous RamBlade thread as a few critical things have changed.
RamBlade is an SMT pcb and will be available assembled and in various versions...
(Guess I should state it is essentially the best bits of the TriBlade Prop#2 which we are using for ZiCog)
All versions are designed·to run ZiCog/CPM/PropDos/Catalina programs.
RamBlade V1
RamBlade V2
RamBlade SBC V??
· Home of the MultiBladeProps: TriBlade,·RamBlade, RetroBlade,·TwinBlade,·SixBlade, website
Post Edited (Cluso99) : 10/19/2009 3:39:16 AM GMT
RamBlade V1
- Propeller and 5MHz crystal·(80MHz)
- 128Kx8 55nS SRAM
- microSD socket
- Designed to plug into another (host)·Propeller board (Proto, Demo, etc)
- Requires 5 prop pins for the interface
- 3 to reset and program the RamBlade prop
- 2 to communicate serially to the RamBlade
- No resistor protection on these pins
- 0.1" pin stake holes provided but no connector (can be cheap wires or resistors)
- Requires 3V3 from the host propeller board
- No EEPROM is fitted
- Minimum cost version
RamBlade V2
- Propeller designed for overclocking (104MHz/114MHz/120MHz???)
- 512Kx8 55nS SRAM
- microSD socket
- Designed to plug into another (host)·Propeller board (Proto, Demo, etc) or another micro based processor
- Requires 2 prop pins for the interface
- 0.1" pin stake holes provided but no connector (can be cheap wires or protection resistors)
- Optional 3 prop pins for interface
- Onboard 3V3 power regulation for overclocking stability
- Requires 5V from the host propeller board
- AT24C512 (64Kx8) EEPROM is fitted which is disabled after boot
RamBlade SBC V??
- Full specifications TBA, but here·are the basics
- Designed to be a self-contained SBC (single board computer)
- 128Kx8 -or- 512Kx8 55nS SRAM
- microSD socket
- EEPROM loaded with code to boot from a microSD card binary
- 0.1" pin holes for external PropPlug (optional - not supplied)
- Onboard 5V power regulation from 6-9VDC Power Pack (not supplied)
- Up to 5 pins are available for the onboard interfaces
- 2 pins are available for the onboard interfaces
- Up to 3 additional pins may be taken from the SRAM addressing, reducing available SRAM
- External connectors (total of 5 pins excluding power described above available by links)
- Power connector for external 6-9VDC Power Pack (not supplied)
- PS2·6pin with
- 2 pins: +5V & Gnd
- 2 pins: (with protection resistors)
- PS2 Keyboard or mouse
- TTL/CMOS 3V3 serial
- RS232 semi compatible (design to be proven)
- RCA connector (TV composite video) with onboard resistors
- 1, 2 or 3 pin video
- VGA - 7 connection holes (no connector) with onboard resistors
- 1 pin for combined HS & VS including decoder circuit
- 1, 2 or 3 pin RGB (maybe limited color)
- TV/VGA designed for 80x25 characters
- Later provision to convert PS2 CLK & DATA pins to 1 serial input pin (unproven)
- Will fit into a case
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80) , MoCog (6809)
Designed to plug into another (host) Propeller board (Proto, Demo, etc)
is a neat idea. Most people would have at least one of the the above boards, so the marginal cost of moving to a zicog/triblade/large memory model for catalina etc is a tiny extra board and a few chips.
www.smarthome.viviti.com/build
Or, you can just use the few extra bits to add a either a PC (2 pin serial and a terminal program) or add a PS2 keyboard and a monitor (TV or VGA) and you have a complete SBC (e.g. CPM2.2, CPM3, etc) system. In fact, it is designed to fit into a Hammond 1593K box (Digikey HM356-ND $2.88 for grey, or Rapid 30-1847 UK 1.75 pounds for translucent blue).
I am working on a tiny micro to convert the PS2 2pin interface to 1pin serial (saves a pin and costs about 50c). The TV can be 1 pin whereas the VGA requires 2 pins. So, with the 1 pin keyboard and 1 pin TV, you still have the full 512Kx8 available.
The total pcb size is approx 1.3"x2.2" but the RamBlade section actually fits into a subsection 1"x1.6"
Just to make sure I understand the possible options - on the Ramblade SBC, can you confirm that you could have the following configuration:
- PS/2 connector for kbd (2 pins)
- RCA conector for video (1 pin - b/w only)
- 256kb addressable RAM
Presumably to do this you have to fit a 512kb RAM, but you cannot address the upper half while using the above connectors. Is this correct?
Ross.
Using a different micro to support the Prop? Surely that's cheating!
Ross.
The extra's are for the I/O options for SBC mode only, of which there is a perfectly good reason to add.
I don't want to sacrifice speed or simplicity to use a latch. The micro is as cheap (well almost) as a gate and if used, it saves a valuable RAM address pin.
When I reveal the complete circuit you will see it's simplicity.
Oh for just a couple of extra pins
