RamBlade: Prop+SRAM+microSD addon to run ZiCog/CPM/PropDos/Catalina, etc. SBC s — Parallax Forums
Cluso99Cluso99 Posts: 18,071
edited 2009-10-10 07:02 in Propeller 1
Project re-specified... please see...
http://forums.parallax.com/showthread.php?p=849265
The RamBlade is almost ready. Please ignore the previous RamBlade thread as a few critical things have changed.
RamBlade is an SMT pcb and will be available assembled and in various versions...
(Guess I should state it is essentially the best bits of the TriBlade Prop#2 which we are using for ZiCog)
All versions are designed·to run ZiCog/CPM/PropDos/Catalina programs.
RamBlade V1
  • Propeller and 5MHz crystal·(80MHz)
  • 128Kx8 55nS SRAM
  • microSD socket
  • Designed to plug into another (host)·Propeller board (Proto, Demo, etc)
  • Requires 5 prop pins for the interface
    • 3 to reset and program the RamBlade prop
    • 2 to communicate serially to the RamBlade
    • No resistor protection on these pins
    • 0.1" pin stake holes provided but no connector (can be cheap wires or resistors)
  • Requires 3V3 from the host propeller board
  • No EEPROM is fitted
  • Minimum cost version
RamBlade V2
  • Propeller designed for overclocking (104MHz/114MHz/120MHz???)
  • 512Kx8 55nS SRAM
  • microSD socket
  • Designed to plug into another (host)·Propeller board (Proto, Demo, etc) or another micro based processor
  • Requires 2 prop pins for the interface
    • 0.1" pin stake holes provided but no connector (can be cheap wires or protection resistors)
  • Optional 3 prop pins for interface
  • Onboard 3V3 power regulation for overclocking stability
    • Requires 5V from the host propeller board
  • AT24C512 (64Kx8) EEPROM is fitted which is disabled after boot
RamBlade SBC V??
  • Full specifications TBA, but here·are the basics
  • Designed to be a self-contained SBC (single board computer)
  • 128Kx8 -or- 512Kx8 55nS SRAM
  • microSD socket
  • EEPROM loaded with code to boot from a microSD card binary
  • 0.1" pin holes for external PropPlug (optional - not supplied)
  • Onboard 5V power regulation from 6-9VDC Power Pack (not supplied)
  • Up to 5 pins are available for the onboard interfaces
    • 2 pins are available for the onboard interfaces
    • Up to 3 additional pins may be taken from the SRAM addressing, reducing available SRAM
  • External connectors (total of 5 pins excluding power described above available by links)
    • Power connector for external 6-9VDC Power Pack (not supplied)
    • PS2·6pin with
      • 2 pins: +5V & Gnd
      • 2 pins: (with protection resistors)
        • PS2 Keyboard or mouse
        • TTL/CMOS 3V3 serial
        • RS232 semi compatible (design to be proven)
    • RCA connector (TV composite video) with onboard resistors
      • 1, 2 or 3 pin video
    • VGA - 7 connection holes (no connector) with onboard resistors
      • 1 pin for combined HS & VS including decoder circuit
      • 1, 2 or 3 pin RGB (maybe limited color)
    • TV/VGA designed for 80x25 characters
    • Later provision to convert PS2 CLK & DATA pins to 1 serial input pin (unproven)
  • Will fit into a case
· Home of the MultiBladeProps: TriBlade,·RamBlade, RetroBlade,·TwinBlade,·SixBlade, website
· Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)
· Search the Propeller forums·(uses advanced Google search)
Post Edited (Cluso99) : 10/19/2009 3:39:16 AM GMT
