It seems The new Parallax sensor Pressure has a resolution mistake it is 1.5 Pa — Parallax Forums
markustermarkuster Posts: 184
edited 2009-10-08 16:06 in BASIC Stamp
hi ,
It seems that the new Parallax sensor Pressure has a resolution
mistake, it is 1.5 Pa and not 1.5KPa
The mistake is at the PDF and at the web site.
Please confirm.
Thanks, Mark
  • James LongJames Long Posts: 1,181
    edited 2009-10-07 03:05
    markuster said...
    hi ,
    Please confirm.
    Thanks, Mark
    Mark,
    Yes....there is an error on Parallax's side. The resolution is 1.5 Pa for the chip. I just checked the data sheet from VTI.
    James L
    James L
    Partner/Designer
    Lil Brother SMT Assembly Services
    Please note: Due to economic conditions the light at the end of the tunnel will be turned off until further notice. Thanks for your understanding.
  • Steph LindsaySteph Lindsay Posts: 767
    edited 2009-10-07 20:00
    Thank you both for your eagle eyes! The error has been corrected on the product page and product documentation.
    -Steph Lindsay
    Editor, Parallax Inc.
    edited 2009-10-07 20:42
    Steph Lindsay (Parallax) said...
    -Steph Lindsay
    Steph,
    I'm sure Mark and I agree......we try to keep Parallax on top.....so we do not see our favorite micro-controllers go away.
    James L
    James L
    Partner/Designer
    edited 2009-10-08 06:55
    A change of 1.5 Pa amounts to about 5 inches (12 cm) change in altitude near the earth's surface. How does this sensor do on noise at that resolution?
    The range of the sensor is 30 kPa to 120 kPa. To put that in perspective, 1 atmosphere standard pressure is 101.325 kPa
    (=1013.25 millibar = 760 mmHg = 14.7 psi)
    At the extremes, 30 kPa corresponds to an altitude of about 30000 feet (9000+ meters), and 120 kPa would be about 6 feet under water (absolute, including atmospheric pressure at the water surface).
    Tracy Allen
    www.emesystems.com
    Tracy Allen said...
    Tracy,
    I have one and have played with it quite a bit.
    If you have clean power the sensor does bounce some....but with an average of a couple of seconds it is real accurate.
    Unfortunately it is not the Parallax one. I bought mine a year or so ago.
    James L
    James L
    Partner/Designer
