ethernet control of a robot
i am building a full scale independent robot it is going to take approximately 5 grand to build estimated it will probably wiegh in at 750 to 1000 poiunds and i want to me able to control this machine via ethernet i would like to get all the systems to talk to the main system via ethernet and i am not sure how to do that 5 grand is only an estimate if my total price is higher oh well does anyone have any ideas how to do this· the main computer on board will comunicate with a master computer such as a laptop wirelesly i will have to incorperate a wireless router. my power source for this machine if i can pull it off will be a chainsaw motor converted to propane (for indoor use) to operate the generator i am still not sure how it will all work out if i am able to use parallax products i will because i trust parallax in the most extreme conditions plus they are very easy to work with as we all know
Parallax posesses power beyond belief.
Believe in it.
Visit me at
http://jrelectromech.services.officelive.com/default.aspx
Believe in it.
Visit me at
Apparently Parallax will be coming out with some sort of WiFi adapter that can be used with a Propeller (and maybe a Stamp too). There are no details available, but it may be available by the time you're ready to need one and it might be usable with an embedded PC's serial port.
Believe in it.
Visit me at
If you’re interested in internet controlled robotics using the Propeller chip you should check out Steve Norris’ work at http://www.norrislabs.com/ He’s done this using our products and had great success. Take care.
Chris Savage
Parallax Engineering
50 72 6F 6A 65 63 74 20 53 69 74 65
thank you for the link chris
Believe in it.
Visit me at
Believe in it.
Visit me at
