Have problems upgrading to BS2p40 from BS2
I recently got the 40pin BS2p40 and the professional development board (PDB). I have been using the BS2 with Board of Education board. I am having trouble getting data out my sensors like sensiron, LM 34, Memphis 2 axis accel, etc thru LTC1298 ADC when I use BS2p40 with PDB. I mean the same program runs fine with BS2, and when I connect the wires to my BS240p, DEBUG screen shows all zeros. RCTIME programs are working·fine for thermistors with BS240p. What am I missing here? I though switching from BS2 to BS2p40 would be easy.
My sensors are on a seperate proto board. I am powering the board from either Board of Education or from PDB. As I said earlier, no problems with Board of education but getting all zeros with PDB. Please help...
Also, be sure to see AUXIO and MAINIO in the Stamp reference manual -- if you have sensors on AUXIO P0-P15, you need to use the AUXIO command before using those pins (and vice versa).
Posting a program and schematic (or photo of your setup) would certainly help.
