FSRW - is "-1000" the new "-13" and if so, what does it mean? — Parallax Forums
HughHugh Posts: 362
edited 2009-10-05 20:14 in Propeller 1
Sorry chaps,
I tried searching for this, without success...
Having got data being read to/from an SD card with FSRW v1.6 I thought I'd neaten things up by moving it to a protoboard.
FRSW v2.4 is returning "-1000" and FSRW v1.6 is returning "-13" - are these both the same and if so, what do they mean?
Wiring - check!
Format - check!
Basepin = Prop pins - check!
Any other ideas? I'm even using the Sparkfun b/out board rather than an SD adapter.
Any thoughts gratefully received.
Hugh
Hugh - the thinking woman's Geoffrey Pyke.
  • HughHugh Posts: 362
    edited 2009-10-02 15:32
    Sorted. I am just stupid. Sorry!
  • rokickirokicki Posts: 1,000
    edited 2009-10-02 16:42
    Hmm, maybe I need to put some effort into making those error messages more intelligible.
    Would you be willing to share what the problem was?
    edited 2009-10-02 18:55
    "Would you be willing to share what the problem was?"
    Yes I would. I hereby state, on a very public and easily accessible forum, that I, Hugh, am as stupid as a brick - as stupid as a brick that didn't go to school.
    I [noparse][[/noparse]wrongly] assumed that the pads circled in the attachment were a group of pads connected to VDD (due to the difference in colour). Once I linked them together and to VDD it worked perfectly. My dog has intestinal parasites that know better.
    615 x 476 - 98K
    edited 2009-10-02 21:55
    Hugh, thanks for the report; no need to be embarrassed. If you're not making
    mistakes fast and furiously, you're not trying hard enough, or you're doing the
    same thing over and over again.
  • KyeKye Posts: 2,200
    edited 2009-10-02 23:47
    You could make the error messages return a string.
    Like:
    abort string("Something went wrong!")
    Then it would be really easy to figure out the problem if a terminal is attached printing out the errors. The memory cost of doing this however is very high.
    Nyamekye,
    edited 2009-10-03 02:00
    Perhaps just a list of messages and their numbers in the programs comments smile.gif
    · Home of the MultiBladeProps: TriBlade,·RamBlade, RetroBlade,·TwinBlade,·SixBlade, website
    · Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80) , MoCog (6809)
  • lonesocklonesock Posts: 917
    edited 2009-10-03 18:00
    Some of the error codes are generated inside the lower level block driver. This is from the top of the mb_rawb_spi.spin file:
      ' Error codes
      ERR_CARD_NOT_RESET            = -1
      ERR_3v3_NOT_SUPPORTED         = -2
      ERR_OCR_FAILED                = -3
      ERR_BLOCK_NOT_LONG_ALIGNED    = -4
      ' These errors are for the assembly engine...they are negated inside, and need to be <= 511
      ERR_ASM_NO_READ_TOKEN         = 100
      ERR_ASM_BLOCK_NOT_WRITTEN     = 101
      ' NOTE: errors -128 to -255 are reserved for reporting R1 response errors
      ERR_SPI_ENGINE_NOT_RUNNING    = -999
      ERR_CARD_BUSY_TIMEOUT          = -1000
    I know the fsrw layer can have additional abort error codes. Rokicki and I have not collaborated yet on "One error code list to rule them all", but it's on our extended todo-list. Sorry for the confusion. Kye, you're right, that technique would be both easy to see what's going on (given a serial connection or display), and fairly memory expensive [noparse][[/noparse]8^)
    Jonathan
    lonesock
    Piranha are people too.
  • ericballericball Posts: 774
    Put in an ErrorString( ErrNo ) function in frsw.spin which returns a pointer to the error string. Put the same function in the block driver so if it's not an frsw error then it can be passed along to the block driver.
    Composite NTSC sprite driver: Forum
    NTSC & PAL driver templates: ObEx Forum
    OnePinTVText driver: ObEx Forum
