FSRW - is "-1000" the new "-13" and if so, what does it mean?
Hugh
Sorry chaps,
I tried searching for this, without success...
Having got data being read to/from an SD card with FSRW v1.6 I thought I'd neaten things up by moving it to a protoboard.
FRSW v2.4 is returning "-1000" and FSRW v1.6 is returning "-13" - are these both the same and if so, what do they mean?
Wiring - check!
Format - check!
Basepin = Prop pins - check!
Any other ideas? I'm even using the Sparkfun b/out board rather than an SD adapter.
Any thoughts gratefully received.
Hugh
Hugh - the thinking woman's Geoffrey Pyke.
Wiring - check!
Format - check!
Hugh
Would you be willing to share what the problem was?
Yes I would. I hereby state, on a very public and easily accessible forum, that I, Hugh, am as stupid as a brick - as stupid as a brick that didn't go to school.
I [noparse][[/noparse]wrongly] assumed that the pads circled in the attachment were a group of pads connected to VDD (due to the difference in colour). Once I linked them together and to VDD it worked perfectly. My dog has intestinal parasites that know better.
mistakes fast and furiously, you're not trying hard enough, or you're doing the
same thing over and over again.
Like:
abort string("Something went wrong!")
Then it would be really easy to figure out the problem if a terminal is attached printing out the errors. The memory cost of doing this however is very high.
Nyamekye,
· Home of the MultiBladeProps: TriBlade,·RamBlade, RetroBlade,·TwinBlade,·SixBlade, website
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80) , MoCog (6809)
· Search the Propeller forums·(uses advanced Google search)
I know the fsrw layer can have additional abort error codes. Rokicki and I have not collaborated yet on "One error code list to rule them all", but it's on our extended todo-list. Sorry for the confusion. Kye, you're right, that technique would be both easy to see what's going on (given a serial connection or display), and fairly memory expensive [noparse][[/noparse]8^)
Jonathan
lonesock
Piranha are people too.
Composite NTSC sprite driver: Forum
NTSC & PAL driver templates: ObEx Forum
OnePinTVText driver: ObEx Forum
