Video and VGA - resistor selections for use with less pins (RamBlade) — Parallax Forums
Cluso99Cluso99 Posts: 18,071
edited 2009-10-06 00:19 in Propeller 1
I am currently just finalising a pcb design (RamBlade for ZiCog/CPM/PropDos)
I require options for minimum pin counts and resistors.
I will use the 1 pin version of TV, with options for 2 & 3 pin versions as well.
Also, I want to be able to do minimal pin count versions of VGA as an alternative.
For reference, here is thread about minimal pins http://forums.parallax.com/showthread.php?p=796900
I am trying to re-use smt resistors with tiny links for different options.
The keyboard 10K pullups and the 10K/5K for the VGA single pin HS and VS per Phil (PhiPi) will all be done in a single smt resistor package of 8 x 10K 16 pin package (2 parallel 10K -> 5K) and the inverter & buffer (2 inverters) or 2 x exclusive or will be done with an 8 pin 74LVCxxx SOT style chip.
Now, for the series resistors for the VGA option, it seems that 240R for HS, VS and each of the RGB is required. I will need to buffer the RGB since it will likely be driven by 1 common prop pin and 3x30mA will stress the prop. Are the 240R the best for this???
Now for the TV option, 3 pins use 1k1, 560R & 270R. The single pin version was suggested to use 124R (so 120R) series with 191R (so 180R) to ground in parallel with 470pF, although likewise it was suggested that the 191R // 470pF could most likely be dispensed with.
Presuming the 240R are best for the VGA I will have 3 x 240R remaining.... So can I...
* Use 1 x 240R for the single pin TV (or 2 x 240R in parallel -> 120R) ? Which is best.
* Use 1 x 240R and 1 x 480R (2 series 240R) for the 2 pin version of TV ?
* Use 1 x 240R, 1 x 480R (2 series 240R) and add a single 1K1 resistor for the 3 pin TV.
Unfortunately, I want to get my pcb and parts orders away and will not have hardware to test this for another week+
Any help will·be greatly apppreciated smilewinkgrin.gif Analogue and TV/VGA is not my·speciality shakehead.gif
· Home of the MultiBladeProps: TriBlade,·RamBlade, RetroBlade,·TwinBlade,·SixBlade, website
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80) , MoCog (6809)
