Video and VGA - resistor selections for use with less pins (RamBlade)
Cluso99
I am currently just finalising a pcb design (RamBlade for ZiCog/CPM/PropDos)
I require options for minimum pin counts and resistors.
I will use the 1 pin version of TV, with options for 2 & 3 pin versions as well.
Also, I want to be able to do minimal pin count versions of VGA as an alternative.
For reference, here is thread about minimal pins http://forums.parallax.com/showthread.php?p=796900
I am trying to re-use smt resistors with tiny links for different options.
The keyboard 10K pullups and the 10K/5K for the VGA single pin HS and VS per Phil (PhiPi) will all be done in a single smt resistor package of 8 x 10K 16 pin package (2 parallel 10K -> 5K) and the inverter & buffer (2 inverters) or 2 x exclusive or will be done with an 8 pin 74LVCxxx SOT style chip.
Now, for the series resistors for the VGA option, it seems that 240R for HS, VS and each of the RGB is required. I will need to buffer the RGB since it will likely be driven by 1 common prop pin and 3x30mA will stress the prop. Are the 240R the best for this???
Now for the TV option, 3 pins use 1k1, 560R & 270R. The single pin version was suggested to use 124R (so 120R) series with 191R (so 180R) to ground in parallel with 470pF, although likewise it was suggested that the 191R // 470pF could most likely be dispensed with.
Presuming the 240R are best for the VGA I will have 3 x 240R remaining.... So can I...
* Use 1 x 240R for the single pin TV (or 2 x 240R in parallel -> 120R) ? Which is best.
* Use 1 x 240R and 1 x 480R (2 series 240R) for the 2 pin version of TV ?
* Use 1 x 240R, 1 x 480R (2 series 240R) and add a single 1K1 resistor for the 3 pin TV.
Unfortunately, I want to get my pcb and parts orders away and will not have hardware to test this for another week+
Any help will·be greatly apppreciated
Analogue and TV/VGA is not my·speciality
· Home of the MultiBladeProps: TriBlade,·RamBlade, RetroBlade,·TwinBlade,·SixBlade, website
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80) , MoCog (6809)
· Search the Propeller forums·(uses advanced Google search)
Visit some of my articles at Propeller Wiki:
MATH on the propeller propeller.wikispaces.com/MATH
pPropQL: propeller.wikispaces.com/pPropQL
pPropQL020: propeller.wikispaces.com/pPropQL020
OMU for the pPropQL/020 propeller.wikispaces.com/OMU
One of my new designs justs uses just the one value of those little quad smd resnets for both the VGA and TV.
If I use four 470R resnets I get enough to run the standard VGA or the TV signals from 8 I/O. Normally the TV signals would have multiples and sub-multiples of 560R but 470R is a good compromise. I will get to try it out this week.
P.S. Scrub that, I just realized you need something different
*Peter*
Post Edited (Peter Jakacki) : 10/5/2009 8:53:26 AM GMT
Your current circuit is providing a resistive link between P16, P17 & P18 from the TV thereby causing interference between HS, VS and B :-( see post below.
Please let me know how it goes.
Post Edited (Cluso99) : 10/6/2009 12:22:39 AM GMT
www.smarthome.viviti.com/build
As the port pins are always outputs there is no way that a weak circuit can overdrive these pins. They operate as a binary ladder in R/2, R, R*2 values but any "feedback" is purely resistive in the order of hundreds of ohms or more back to a low-impedance I/O pin. The effect that any resistively coupled signals would have on the signal would be negligible. I have run a similar circuit before but this is the first time I have used identical resnets. Anyway I was squeezed on these particular proto boards and that pcb area is either fitted with fiber optic components or an RJ-45 for the AV along with the resnets.
*Peter*
@PhiPi, I was thinking while discussing the circuit with Peter, RGB cannot require 30mA per pin if we are using 240R in series, so buffering the RGB will not be required if driving all from 1 prop pin. However, we will require some drive level for the single pin HS and VS since it is a ladder divider using 10K/5K/5K/10K.
