Thanks for all the help!
DiverBob
I just wanted to thank everyone for their help. This help consisted of either helping me with specific programing problems or the many people's generous code donations to the exchange.
I have nearly finished a project that has taken almost 2 years to complete by sending out the first 2 prototypes for testing. Talk about cutting back on my stress levels! Now I spend the next couple of months tweeking the software and design as the testers identify issues.
For those of you who haven't read some of my earlier threads, I am a shipwreck diver that uses a rebreather to explore these ships from the past. Since a rebreather recycles oxygen it is vital to know what you are breathing at all times. To do that most rebreathers have 3 independent O2 monitoring cells that create a linear millivolt output based on the exposed O2 level. I take the millivolt output from th eO2 cells, amplify it, process it in an micochip ADC processor and display the results using a organic LED display system that uses a prop to control the display. That was actually the easy part, the hard part was designing the housings that allow the system to stay waterproof down to ~400 feet.
The prop code uses the Brillidea display driver, basic I2C Driver, FullDuplexSerial, FloatString, and Numbers from the exchange. The code for the prop is fairly complex and I'm down to only about 400 longs left, so I've been optimizing the code to recover memory but may need to come up with some other ideas soon since I want to add a depth pressure sensor, temperature and digital compass capabilities to the system next. So I will still be around reading and watching some of the exciting projects and problems other people run into here in this forum.
I've attached some photos of the unit and the display.
Again, Thank you everyone for your invaluable help - an especially big thank you to Timothy Swieter·for his display driver, that driver pretty much pulled everything together and allowed me to concentrate on other things!
Bob Sweeney
Bob Sweeney
Given the difficulty I have in just finding a plastic box to fit stuff I can't imagine the added difficulty of locating something that is dead-nuts water tight down to 400ft and allows user input. Really nice looking project.
There are 3 main components to the system, a switch pendant (3 stainless steel piezo NO switches, no moving parts), the battery box (uses 2 Li-ion 3.6v AA sized batteries and contains the amplifier and microchip ADC 8 pin processor chip that sends the ADC output serially to the prop when requested) and the display unit itself (uses the 0.96 diagonal micro organic LED with prop).
I have a home-made CNC mill and lathe in the basement so all the housings are re-produceable. However, each component went through quite a few revisions before I got things the way I wanted them. I used up a lot of raw materials in this project. But the end product is worth it! I have been diving with an earlier prototype the last 2-3 months with better success than I initially expected·-·although there were a few hiccups along the way! The plan is that this will become a commerial product·early next year.
Bob
Post Edited (DiverBob) : 10/4/2009 4:10:06 PM GMT
Chat in real time with other Propellerheads on IRC #propeller @ freenode.net
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
www.tdswieter.com
· Home of the MultiBladeProps: TriBlade,·RamBlade, RetroBlade,·TwinBlade,·SixBlade, website
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80) , MoCog (6809)
2 years at elevated stress levels can't be good.
Sorry, I'm not a diver....No, not going to happen.
Here's wishing you nothing but success in the commercial market.
Roger
My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
