Thanks for all the help! — Parallax Forums
DiverBobDiverBob Posts: 1,127
edited 2009-10-05 00:56 in Propeller 1
I just wanted to thank everyone for their help. This help consisted of either helping me with specific programing problems or the many people's generous code donations to the exchange.
I have nearly finished a project that has taken almost 2 years to complete by sending out the first 2 prototypes for testing. Talk about cutting back on my stress levels! Now I spend the next couple of months tweeking the software and design as the testers identify issues.
For those of you who haven't read some of my earlier threads, I am a shipwreck diver that uses a rebreather to explore these ships from the past. Since a rebreather recycles oxygen it is vital to know what you are breathing at all times. To do that most rebreathers have 3 independent O2 monitoring cells that create a linear millivolt output based on the exposed O2 level. I take the millivolt output from th eO2 cells, amplify it, process it in an micochip ADC processor and display the results using a organic LED display system that uses a prop to control the display. That was actually the easy part, the hard part was designing the housings that allow the system to stay waterproof down to ~400 feet.
The prop code uses the Brillidea display driver, basic I2C Driver, FullDuplexSerial, FloatString, and Numbers from the exchange. The code for the prop is fairly complex and I'm down to only about 400 longs left, so I've been optimizing the code to recover memory but may need to come up with some other ideas soon since I want to add a depth pressure sensor, temperature and digital compass capabilities to the system next. So I will still be around reading and watching some of the exciting projects and problems other people run into here in this forum.
I've attached some photos of the unit and the display.
Again, Thank you everyone for your invaluable help - an especially big thank you to Timothy Swieter·for his display driver, that driver pretty much pulled everything together and allowed me to concentrate on other things!
Bob Sweeney
640 x 427 - 49K
640 x 427 - 35K
640 x 434 - 50K
640 x 412 - 50K
640 x 427 - 44K
    edited 2009-10-04 14:50
    Wow. That is flat-out nice!
    Given the difficulty I have in just finding a plastic box to fit stuff I can't imagine the added difficulty of locating something that is dead-nuts water tight down to 400ft and allows user input. Really nice looking project.
  • DiverBobDiverBob Posts: 1,127
    edited 2009-10-04 16:02
    I didn't mention it earlier but this display is designed to mount to the divers mouthpiece (dive surface valve) and it can be positioned so that the diver can see the display through their mask all the time. Although most divers have another wrist-mounted computer there are times that both hands are busy and having the O2 levels always visible is a valuable safety feature.
    There are 3 main components to the system, a switch pendant (3 stainless steel piezo NO switches, no moving parts), the battery box (uses 2 Li-ion 3.6v AA sized batteries and contains the amplifier and microchip ADC 8 pin processor chip that sends the ADC output serially to the prop when requested) and the display unit itself (uses the 0.96 diagonal micro organic LED with prop).
    I have a home-made CNC mill and lathe in the basement so all the housings are re-produceable. However, each component went through quite a few revisions before I got things the way I wanted them. I used up a lot of raw materials in this project. But the end product is worth it! I have been diving with an earlier prototype the last 2-3 months with better success than I initially expected·-·although there were a few hiccups along the way! The plan is that this will become a commerial product·early next year.
    Bob
    Post Edited (DiverBob) : 10/4/2009 4:10:06 PM GMT
    edited 2009-10-04 16:27
    Thanks for posting up your finished work. I'm just going to echo the sentiments others have and say, "Nice!" --(really e-ffing nice!)
    Chat in real time with other Propellerheads on IRC #propeller @ freenode.net
    Safety Tip: Life is as good as YOU think it is!
    edited 2009-10-04 19:25
    Thanks DiverBob for posting your progress and the pictures. What you have created looks beautiful!
    Timothy D. Swieter, E.I.
    www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
    www.tdswieter.com
    edited 2009-10-04 20:30
    Very nice work DB. Thanks for letting us see it.
    edited 2009-10-04 23:17
    Very nice indeed Bob. Congratulations, thanks for posting, and kudos to those who helped you smile.gif
    · Home of the MultiBladeProps: TriBlade,·RamBlade, RetroBlade,·TwinBlade,·SixBlade, website
    · Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80) , MoCog (6809)
    · Search the Propeller forums·(uses advanced Google search)
  • Roger LeeRoger Lee Posts: 339
    edited 2009-10-05 00:17
    Thanks for sharing. Nice practical project.
    2 years at elevated stress levels can't be good.
    Sorry, I'm not a diver....No, not going to happen.
    Here's wishing you nothing but success in the commercial market.
    Roger
  • RaymanRayman Posts: 16,460
    Good job! Looks really professional.
