3D or 2D models of the USB Prop Proto Board — Parallax Forums
JamesRonaldJamesRonald Posts: 39
edited 2009-10-10 13:19 in Propeller 1
We are looking for "USB Prop Proto Board" 3D models (any standard format) or 2D (If that's all there is) in order to generate a couple of Robot chassis assemblies for our Robotics Club ( www.yaaarc.org ). I thought I remembered seeing one some where but perhaps I'm just remembering the 3D models for the wheel kit.
James Ronald
My Robots
  • LeonLeon Posts: 7,620
    edited 2009-10-04 17:53
    Parallax should be able to supply you with that, most PCB packages can output IDF or something like it.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
    Post Edited (Leon) : 10/4/2009 5:59:07 PM GMT
    edited 2009-10-04 21:46
    James,
    We can output the PCB artwork plots, but we've not designed a 3D model of the Propeller Proto Board. The 3D models you've seen were the 12V Motor Mount and Wheel Kit.
    If you want to model the Propeller Proto Board we'll provide the PCB for free in exchange for an eDrawing.
  • heichheich Posts: 26
    edited 2009-10-05 14:50
    Ken Gracey said...
    Hi Ken
    Wath Format and wath level of details?
    I can model a proto on Wings3D (used In Kicad) and, if there are many details needed -and many details given-, maybe i can draw them on Autocad.
    Regards
    Are you looking for a professional PCB/Schematichs software?
    Kicad: GPL. You can do Schematics, PCBS, Gerber interfaces, 3d-views and more
    www.lis.inpg.fr/realise_au_lis/kicad/
  • SapiehaSapieha Posts: 2,964
    edited 2009-10-05 15:07
    Hi Ken.
    If You look on my avatar I kan generate 3D to ProtoBoard if you give me PCB artwork and corect SCH.
    And It is You that decide level of dtails
    Regards
    Christoffer J
    Ps. If You decide that ... PM me
    For every stupid question there is at least one intelligent answer.
    Don't guess - ask instead.
    If you don't ask you won't know.
    If your gonna construct something, make it·as simple as·possible yet as versatile as posible.
    Sapieha
  • TinkerGeekTinkerGeek Posts: 7
    Ken,
    Jim was asking for the model on my behalf. I am part of the YAARC group.
    I can model the board for you in Inventor 9, CATIA V5 R18·or UG NX5. I'm guessing you would like a step file so anyone can use the models in any cad package? I can also do dxf for the 2D folks.
    Please let me know.
    Feel free to contact me directly (I assume you have profile info)
    Roger
