propeller chip lost on com
I was wondering if anyone could help me troubleshoot this problem?· I've been getting this error when loading either ROM or RAM.· It displays·while "verifying ram".· It occurred·occasionally at first, but it has·gradually gotten worse.· Now it takes 5 or 6 tries to get a program loaded.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Try communicating with the PC via the Prop Plug, using serial code and a terminal program. Sending continuous data via the Prop Plug might indicate the cause of the problem.
Check the Prop Plug connector solder joints on the Proto board, as well. One of them might be intermittent. You could see if wiggling the Prop Plug makes a difference.
Leon
Post Edited (Leon) : 10/3/2009 1:31:10 PM GMT
I'll try your suggestions.
agfa
Leon
My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
