propeller chip lost on com — Parallax Forums
agfaagfa Posts: 295
edited 2009-10-04 00:00 in Propeller 1
I was wondering if anyone could help me troubleshoot this problem?· I've been getting this error when loading either ROM or RAM.· It displays·while "verifying ram".· It occurred·occasionally at first, but it has·gradually gotten worse.· Now it takes 5 or 6 tries to get a program loaded.
  • LeonLeon Posts: 7,620
    edited 2009-10-03 11:11
    What hardware are you using?
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
  • agfaagfa Posts: 295
    edited 2009-10-03 11:12
    proto board with a prop plug.
    edited 2009-10-03 13:26
    FWIW, I've never had any problems like that with a Proto board, my own Propeller boards or a prototype data logger board that I'm developing software for. I've got plenty of hardware and two Prop Plugs, which would help with that sort of problem.
    Try communicating with the PC via the Prop Plug, using serial code and a terminal program. Sending continuous data via the Prop Plug might indicate the cause of the problem.
    Check the Prop Plug connector solder joints on the Proto board, as well. One of them might be intermittent. You could see if wiggling the Prop Plug makes a difference.
    Leon
    Post Edited (Leon) : 10/3/2009 1:31:10 PM GMT
    edited 2009-10-03 13:41
    Thanks Leon,
    I'll try your suggestions.
    agfa
    edited 2009-10-03 15:07
    You aren't powering it from a battery, are you?
    Leon
    edited 2009-10-03 16:32
    I have the problem with both batteries and wall wart.· I did try a fresh set of batteries.· I haven't tried your suggestions yet, though.
    edited 2009-10-03 23:22
    Thanks for the help.· It was a printer driver/software.
  • RaymanRayman Posts: 16,058
    edited 2009-10-03 23:29
    Make sure you have the latest version of Prop Tool. Earlier versions had this problem with certian computers...
    I'll do that Rayman.· Thanks
