Ttl 3.3 v
Hello,
I just was given three free Palm TX units. I want to use one as a serial datalogger. I looked up the pinout d found that there is an RX, TX, and Ground pin. It is a TTL but with 0v low and 3.3 high. Just like the prop? Is there a circuit to interface with it that I can send prop serial data to the Palm TX? Anyhelp would be appreciated.
Curtis
Curtis
Just interface the Prop pins directly to the Palm but use series resistors in the TX and RX of around 100 to 1000 ohms.
*Peter*
· Home of the MultiBladeProps: TriBlade,·RamBlade, RetroBlade,·TwinBlade,·SixBlade, website
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80) , MoCog (6809)
It worked. I thought it would be difficult.
Curtis
