Propalyzer Distribution - New Update 1.0.1.4 Available
                    Hello,
This post announces and provides the Freeware Propalyzer Distribution.
This is not nag-ware, etc.... Bug fixes may come if issues are deemed significant by the author.
The release is for Windows PC users with .net 2.0+ pre-installed. Linux mono .net is not supported.
This program does not compete with 'sponsored' applications; the features available are different.
Please see Propalyzer.txt in the .zip for user details.
Please use this thread for Q&A, application feedback, or to point out errors or situations where
Propalyzer does not work as expected. At some point the application may be posted in the obex.
Version 1.0.1.4a:
Allows user to specify the Clock Frequency used for sample periods.
Enables Window edge resizing. Gives Propalyzer an icon for Windows.
Fixes State List window restart problem.
Fixes a Comm Port Options problem.
Fixes an issue where traces added to a group are not correctly dislpayed.
See Bug/Feature record in Propalyzer.txt for update history.
Version 1.0.1.4 had an initial setting problem that 1.0.1.4a fixes.
Propalyzer.exe will not start any install; it will just work if you have .net 2.0+ in your PC.
Please make sure your com port speed is set to 115200. Read Propalyzer.txt for usage.
It is recommended that the PiggyBack Propeller have it's own crystal for use with Propalyzer.
Propalyzer Purpose: To provide a serial interface logic analyzer GUI for a Propeller running capture code. Propalyzer is designed with HP analyzers in mind. It is not an oscilloscope application. Specifically, the timing diagram is displayed in the main window. Users have control over triggers with a bitmask and an arm state. Users can define groups for making data more meaningful. Features: -Serial communications with Propeller -Compile and Download Propeller with Propellent program -Flexible serial port settings -Propeller Clock period to 2 second sample period (2Hz to 80MHz) -Easy to use Mask, Arm, Trigger, Display settings -Two waveform display color variants -A statelist window -Pin Group definitions -Display context controls -Key stroke display controls Propalyzer is a Logic Analyzer; it does not collect and show data in real time like an Oscilloscope. If you want an Oscope use a program that advertises that feature.
Version 1.0.1.4a:
May I suggest you place a reference to Propalyzer in the Prop Tools index thread (see my signature for the thread).
· Home of the MultiBladeProps (SixBladeProp)
· Emulators (Micros eg Altair, and Terminals eg VT100) - index
My cruising website is: ·www.bluemagic.biz
After launching Propalyzer: I only get
For every stupid question there is at least one intelligent answer.
Don't guess - ask instead.
If you don't ask you won't know.
If your gonna construct something, make it·as simple as·possible yet as versatile as posible.
Sapieha
Sorry for the trouble. Please find corrected version Propalyzer_1011.zip attached in the top post.
It is simply amazing that the program ever worked for anyone except me.
--Steve
--Steve
Next problem.
Look at Pictures.
First look on My setings. My ComPort is "Com15" but On butons marked in picture On Butons it stil wil have "Com1"
Next If I drag Setings window it hides below Propalyzer
Ps. After restart av Propalyzer·it function corect !
Sapieha
Post Edited (Sapieha) : 2/27/2009 3:03:03 PM GMT
Wow! You have many COM ports! Thanks for your efforts and not giving up. I was able to reproduce the problem.
For the time-being, I hope restarting the program is an ok workaround. I will update the application with a fix later.
--Steve
--Steve
Enjoy [noparse]:)[/noparse]
--Steve
You should offer a "Propalyzer PCB board" (populated or unpopulated, SMD or through hole). Something that has two propeller chips with the proper electrical connections, and possibly a USB to Serial chip too. It should be made to just plug into a standard socket, and would be left there during development. Once done, just pop it out and replace it with a regular propeller chip. I'd try and use your program, but I don't want to have to solder chips together or bend pins and all that. If you do it with SMD then it could occupy the same area as a regular DIP prop.
I have the same problem, regardless fo the advice that it is "easy" to go SMT. But the PropII will only be offered in SMT, as far as I can tell, so a permanent solution has to be found. Perhaps Parallax will offer a breakout board with xtal, regulator and and other naughty bits.
JMH
Did you use level shifting with this circuit ? I was wondering how fast the series MOSFET circuit can switch. Have you any idea ?. Something like the 2N7002.
I mean something like this circuit:
http://forums.parallax.com/attachment.php?attachmentid=41645
thanks!
Visit some of my articles at Propeller Wiki:
MATH on the propeller propeller.wikispaces.com/MATH
pPropQL: propeller.wikispaces.com/pPropQL
pPropQL020: propeller.wikispaces.com/pPropQL020
OMU for the pPropQL/020 propeller.wikispaces.com/OMU
WOW!
Does this require the Propalyzer or Propalyzer2 board?
What type of probes are typically used?
http://forums.parallaxinc.com/www.pctestinstruments.com/images/xkm.pdf
They come with that LA. But I think they can be bought somewhere else.
Andrew Williams
WBA Consulting
The schematic shows 2 channels that can be set to different voltages 5 to 3.3, 5 to 1.6, 3.3 to 2.8, etc .... Maybe I can do some measurements later today.
The circuit I've used mostly as mentioned in the first post is the one below. I just set it on top of the Propeller I want to test.
I've recently added a 6.25MHz crystal to that so there is less dependency on the device under test for clock (this requires a small Spin _xinfreq adjustment). It still relies on the power though.
The Propalyzer2.jpg picture above was an attempt at making a PCB with a QFN Propeller chip. Good size for a DIP40 - not so good for my soldering skills. I would like to see some kind of a PCB that adds value (maybe with level shifter options, etc...) for use with the software.
I really like those easy hook connectors. If I could buy about 1000 of them, I would make a hardware kit [noparse]:)[/noparse] Regarding Radio Shack alligator clips: those should work too. With any connector, I suggest keeping your wires really short. Stay under 12" (300mm) if possible.
Happy Propellering.
--Steve
Propeller Tools
Just for documentation purposes, maybe this link could help
www.curiousinventor.com/guides/Surface_Mount_Soldering/QFN
Regards
Hector
Are you looking for a professional PCB/Schematichs software?
Kicad: GPL. You can do Schematics, PCBS, Gerber interfaces, 3d-views and more
www.lis.inpg.fr/realise_au_lis/kicad/
--Steve
Propeller Tools
Edit: I thought the LA I have have mosfets as level shifters... but it hasn't. Only 2 series resistors, one capacitor and bias voltage.
Version 1.0.1.3 had over 250 downloads. User feedback has been very encouraging.
Version 1.0.1.3 has been removed from the top post; if you really need it, I can provide it.
Based on user feedback, this release allows setting the Clock Frequency used for the sample period.
Also, the source code may be release specifically for non-Windows users experiments if there is interest.
Surely mono supports .net version 2.0 by now [noparse]:)[/noparse]
Some problems to start it with to big patch to it.
H:\Arbets\_Div Spin Code\-_ HardWare\HardWare\Propalyzer_1010\Propalyzer_1014 - on that path it wil not start.
But if I copy it to Z:\Propalyzer_1014 it is not problem to start it
Regards
Christoffer J
Sapieha
--Steve
Sorry -- it was not start problems ... BUT on first start it complain that frequensy is not correct.
I mised that info (Have to many programs ON) not saw it.
After first start and give program corect frequency it is not problem.
If posible give Yours program default Frequency on first start and it wil not be confusions.
Regards
Christoffer J
Sapieha
Thanks for clarifying. I set the default to 80MHz for the option text box. I guess another startup thing causes the problem. Will have a look.
--Steve
On my system Not any default at all on first start.
Regards
Christoffer J
Sapieha
Post Edited (jazzed) : 10/2/2009 8:11:02 PM GMT
Well that's a challenge I had to take up. Here on Debian I just installed some mono and winforms. So now I can start Propalyzer:
# mono Propalyzer.exe
Everything seems to come up fine and I can play with all the widgets and options.
BUT I don't see any data traces or anything at all in the trace window.
If I use the "Connect Serial Data To debug Window" button the debug window opens and eventually I see a couple of things like "m00000000a00000000t00000000p12s0c" appearing very slowly after some time.
Using the terminal window in BST I can see "OK>" prompts and what looks like a lot of captured data when I hit "C"
416 $F800FF00 $F800FF00 $F800FF00 $F800FF00 $F800FF00 $F800FF00 $F800FF00 $F800FF00
424 $F800FF00 $F800FF00 $F800FF00 $F800FF00 $F800FF00 $F800FF00 $F800FF00 $F800FF00
432 $F800FF00 $F800FF00 $F800FF00 $F800FF00 $F800FF00 $F800FF00 $F800FF00 $F800FF00
440 $F800FF00 $F800FF00 $F800FF00 $F800FF00 $F800FF00 $F800FF00 $F800FF00 $F800FF00
448 $F800FF00 $F800FF00 $F800FF00 $F800FF00 $F800FF00 $F800FF00
OK>
So what's up? How should I proceed to check, set, whatever to get this working ?
P.S. My Prop has a 6.5536MHz XTAL and PLL16.
For the time being, I assume you have changed the Propalyzer.spin xtal to 6_553_600 and hit the download toolbar button.
Gotta go do wifey time [noparse]:)[/noparse]
--Steve
