Fried USB problem
The USB section of one of my USB Proto Boards got fried somehow. It may have had a problem from the beginning - I had noticed that the red LED on the USB section was on much more than normal - but since the board seemed to be behaving normally in all other ways I went ahead and used it. I've gone over my wiring on the protoboard a whole bunch of times and can't find anything I've done (this was a fairly simple project) that should affect the USB section. In particular, I have no connections to any of the IO pins in the P24 through P31 range. But two days ago, it suddenly had no USB support. The USB LED's don't blink at all, and the computer can no longer see the board.
But I really don't want to trash the board, so I've been thinking about putting a 4 pin header on and using my PropPlug to program the Prop. Are there traces from the now dead USB section I will need to cut to protect my PropPlug from whatever is wrong with the on board USB??
It is posible it is only some soldering problems.
Push carefuly USB connector to PCB in same time You test connection to PC else push FTDI IC same way under test.
Mostly it is them that can have solderings problems.
But my gues is that it is USB conector that have solderings problems.
Regatds
Christoffer J
For every stupid question there is at least one intelligent answer.
Don't guess - ask instead.
If you don't ask you won't know.
If your gonna construct something, make it·as simple as·possible yet as versatile as posible.
Sapieha
