Super Prop(now dead due to price) — Parallax Forums
mctriviamctrivia Posts: 3,772
edited 2009-10-02 03:42 in Propeller 1
If you have not seen my thread in the sandbox you may be interested to know i have designed a product i call the Super Prop. It is almost the exact same size as DIP40 Prop(is slightly longer on each side) and contains:
*Prop
*2,4, or 8MB RAM
*8MB FLASH
*Max II 1270
It is pin for pin compatible with the prop and can be used as direct replacement in any product already designed for the DIP40 prop.
The max II is used as a prop to expanded memory controller and some believe it should be also usable as a high res graphics driver. At present no code has been written for the Max II on board but the device can still be used as regular dip40 prop in mean time.
To VHDL developers willing to preorder the chip I will be offering a Super Prop and Programming Rig for $200.
I plan to have the chips build for end of October, 2009 but I need to know how many people would be willing to buy? I can buy parts on credit but need to Sell 15 before November 25 to not go bankrupt.
Price for 8MB:
1: $250
10: $230
25: $200
50: $180
100: $165
250: $155
500: $150
1000+: Ask for quote
Subtract $15 for 4MB
Subtract $30 for 2MB
See picture below for simulation. Pads on top/bottom are for pins like on basic stamp, pads on sides are for optional extra io.
resistors in top right, bottom left, and middle are jumpers for options. they are populated as needed.
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
Post Edited (mctrivia) : 10/2/2009 2:12:12 AM GMT
    edited 2009-09-26 14:35
    just noticed in my simulation prop is shown wrong. pin 1 is in bottom left corner not top left like picture shows.
  • W9GFOW9GFO Posts: 4,010
    edited 2009-09-26 18:12
    I am interested, not as a customer but just because it is well,.. interesting. A CPLD is well beyond my proficiency level and will be for quite a while. I see that the Max II development kit is $150.00 and you mention that developers that pre-order will get the programing kit included for $200.00. I'm assuming that the programming kit is included even if you don't pre-order, but at the higher $250 price point. Is that correct?
    If not, then I am not understanding why it is five times the cost of a Prop Module.
    Rich H
    The Servo Boss, a 12 channel servo tester kit from Gadget Gangster.
    edited 2009-09-26 18:31
    The programming rig is only needed for vhdl programming.
    People not wanting to program the vhdl will be able to chose the setup they want and I will program before shipping.
    while supplies last I will offer programer for free that ask. Programer is not needed you can solder wires to pads but programer makes it easier.
    edited 2009-09-26 19:16
    Are you trying to tell us something ??
    There are no 40 pin Props around and yours can be used as one, at $250.
    I have three socketed 40 pinners, bidding to start at $50 each (plus extortionate P+P (just like Ebay))
    Style and grace : Nil point
    edited 2009-09-26 19:19
    No. If you just want dip 40 prop I can make them for $16.
    $250 gets you an extra 8mb ram and 8 mb flash
  • AlsowolfmanAlsowolfman Posts: 65
    edited 2009-09-26 19:44
    where is the max II 1270? i was looking it up and it looks like it comes in only 144 tqfp or 256 fbga. i think that would help people understand the price, as it is a 25-40 dollar chip.
    edited 2009-09-26 20:08
    It also comes in 256 mbga which is what I am using. It is on the back side.
    I can render back side later tonight
  • jazzedjazzed Posts: 11,803
    edited 2009-09-26 20:37
    mctrivia said...
    Well that beats the heck out of the Dr. Gouge price for 8MB RAM for QTY 1 at $500 especially
    since this offers a Propeller, clock, CPLD, 8MB Flash, and 8MB SRAM solution all on a DIP40 footprint.
    I find the weekend is the worst time to expect wide spread forum interest on any new topic.
    Maybe Monday morning will bring more responses.
    I really do believe this is a great hobby product concept; however, if it does not ship with a
    functional CPLD and reasonable demo, it is just a work-in-progress to most forum readers.
    --Steve
    Propeller Tools
    edited 2009-09-26 20:43
    Yes I expect early adopters will know vhdl
    I will ship with code as soon as possible.
    Jus good to know if there is a market
    edited 2009-09-27 00:30
    RAM is 10ns - IS61WV102416BLL-10MLI
    cpld IS - EPM1270M256C4N
    These parts alone make up the majority of cost. On top of this I have to fork out $2000 for the 8 layer panels.
    Here is the back of the chip. Final may look slightly different I am trying to squeeze in 1 more option which would make video generation in CPLD easier.
    1451 x 417 - 163K
    1451 x 417 - 150K
    1451 x 417 - 118K
  • Ron SutcliffeRon Sutcliffe Posts: 420
    edited 2009-09-27 07:57
    Very impressive.
    Coupled with a propmod-us_ps_sd, it will make the basis of a great little system.
    I should receive your other boards later this week, so lookng forward to getting my little ForthOS up and running.
    I will have to think about upgrading to your SRam board. Looks just great. The 10ns Sram will be helpful.
    Regards
    Ron
    edited 2009-09-27 19:14
    actually no need to couple with the propmod-us_ps_sd unless you want the power supply.
    on the left and right you will see there are 10 extra pads. i can mount pins upside down on these pads and make a daughter board with 8 io lines and power.
    I am thinking of making one with
    micro SD and mini USB connector
    any daughter board could be designed though. maybe a VGA plug.
    edited 2009-09-30 14:09
    well there have been a lot of downloads of the simulations but not to many saying if they may be interested. i have herd mention of it being to expensive so maybe the better question is what would people be willing to pay for it? I am trying to gather enough information to get a loan or financial partner to make this happen. so the more feedback the better.
  • AleAle Posts: 2,363
    edited 2009-09-30 14:45
    mctrivia:
    I'm one of the ones who would not buy it because the price/features just do not appeal to me or my needs. All the performance in the prop is lost in the slow I/O. Compared to one xmos chip (the single core version) the prop is just too expensive. I can get a 32MB SDRAM and an XMOS chip for far less, have more memory, fast access times without losing that much.
    What can you get for 250 bucks: a netbook or a nice processor with TFT that can even run linux!. It is not a problem if the propeller can access so much memory it is that is just too awkward. There are other architectures more suited, I think.
    If you ask me for a price I'd pay it will be around 50 bucks. More, I get an AVR32 based system (I already have and committed to it getting a JTAG dongle that costs 150 bucks).
    It may not be a bad idea to consider a SDRAM with CPLD (or FPGA, are cheaper at 6 bucks each) in a little bigger 2 or 4 layer board for 40 or 50 bucks. Just my opinion.
    When you started I thought of something in that price range with 1 or max 2 MB RAM. 8 are sweet but you have some 70 bucks just for the SRAM, not worth it.
    Edit: I built, on the cheap, single sided board 100x80, a CPLD+ 512k SRAM. It is only 15 ns SRAM but it will give me an idea how much you can get from something like what you offer. I'll post pictures and everything as soon as I have it up and running.
    Visit some of my articles at Propeller Wiki:
    MATH on the propeller propeller.wikispaces.com/MATH
    pPropQL: propeller.wikispaces.com/pPropQL
    pPropQL020: propeller.wikispaces.com/pPropQL020
    OMU for the pPropQL/020 propeller.wikispaces.com/OMU
    Post Edited (Ale) : 9/30/2009 2:50:37 PM GMT
  • Paul Sr.Paul Sr. Posts: 435
    edited 2009-09-30 15:41
    Well put Ale - and I pretty much agree with what you have said.
    edited 2009-09-30 16:08
    I spent 6 months trying to get a "reasonable" XMM solution running and it burned me out. Reasonable is LMM running about 2MIPS in two COGs or near LMM speed limit at 5MIPS (80MHz) with multiple COGS.
    For LMM instruction direct fetch-ahead/execute XMM, it is not possible to run more than 2MIPS (80MHz). Part of this is because of the way LMM has to work. The other part is the way memory access has to work. If a good cache mechanism were possible with some hardware support such as magnitude comparators in the Propeller, and block loads could be fast enough, you might get close to native LMM, but even that will be less than 5MIPS. The fastest block loads would take 5 COGS + 1 for LMM, leaving 2 COGS for the user. Very unpalatable.
    I have given up and moved on to more promising possibilities with Distributed Propeller Multiprocessing (DPM) to get more memory without sacrificing performance. Having N Propellers with a fast communication path would run code at normal speed either in COG, by LMM, or with Spin, would have N*32KB of user memory, would have memory available for a real application, have lots of pins for I/O, and have memory left over for double-buffered video.
    Of course to make Multi-Propeller Processing (MPP) all transparent to the user, a DPM architecture with RPC/IPC is truly necessary otherwise users (especially the typical Parallax customer) will get totally lost making any headway. But such architecture is complicated and I won't consider developing that to give away, but I'll do it for me.
    While it is a fun hobby to make Propeller do things it was not ever intended to do while enjoying its unique architecture, it is probably best to think practically for achieving realistic non-futzing-around goals: Use what is naturally available in a platform. If the platform does not naturally support what you need, then maybe it's time to move on to something that is a better fit.
  • waltcwaltc Posts: 158
    edited 2009-09-30 16:44
    I'll echo what ALE has said, at first I was interested in your board thinking it would have a price range between $50 and $75, when I read that it would be selling for $250, well there are lots more capable boards out there for that price.
    And using a CPLD that costs 5x as much as a FPGA like the Spartan 3AN was just a good way to drive the price point of the board way beyond that hobbyists can support.
    edited 2009-09-30 17:01
    the cpld only costs twice that of the Spartan 3AN and the Spartan 3AN will not fit in the form factor.
    yes sd ram would significant reduce the price but how hard would the hdml be to write?
    that said sounds like even at cost it is not worth it maybe i will go through the data sheet on a 16MB(128Mbit) SDRAM chip and see if i can get that working.
    edited 2009-09-30 19:03
    One of the problems is the form factor. I know that to replace a DIP prop with your board is a nice goal but is it necessary ? Going to 2 times the surface allows for lower layered board... I am of the idea that an 8 layers board or 6 for that matter has to pay back. Size does not matter because you are replacing a DIP package where the user did not think a QFP or MFP package was needed...
    edited 2009-09-30 19:26
    yes keeping to that small of a form factor did increase the startup price drastically but drops the price in the long run. The bigest expense is the 2MB SRAM chips. If I can get an SDRAM chip working in the same form factor would drop the price almost $80 and double the amount of RAM. Ditching onboard prop would reduce startup costs drastically.
    The biggest gain with ditching the form factor is the added IO that can be achieved by utilizing the CPLD pins as IO Expander.
    edited 2009-09-30 21:22
    After doing some research it seems the source code to do SDRAM has already been done www.altera.com/literature/an/an499.pdf
    Would people be interested in a 16MB RAM, 8MB Flash Super Prop?
    Price $150
    edited 2009-10-01 21:35
    Some questions for your design...
    • What is·your design objective?
    • Where is it going to be used?
    • Who are your target customers?
    • Why are you using 10nS or 12nS memory?
    • Why do you have so much memory?
    • Why so small?
    Now for some comments... Please, please take this in the way it is meant - a little advice from someone who has done it all before. If you don't like it, tell me and I will delete this post. (I tried once before and I got flamed)
    • The size and complexity·is making the cost prohibitive
    • Your design sounds good but I just don't see who is going to use it
    • I think it is too complex for the propeller without a specific use
    • Other processors are better suited for this complexity
    • I suspect you will find some issues with pcb layout due to speed, loading, and bypassing
    • The prop cannot actually use 10-12nS memory. The prop spec does not actually give proper timing, but examination of the instruction cycles reveals this.
    • I am just using 55nS although I would prefer 45nS for the 120MHz overclocked prop. 55nS are cheap ($3 for 512KB 5nS)
    • I believe you are targetting the hobbyist market, and unfortunately the only way for any real profit is in high volume·products.
    • I have a Spartan 3A·kit from Avnet·with lots of other things including a PSOC·for $50 (they were·$40 when I bought it).
    From my experience with the TriBlade...·· My original design requirements...
    • I had a few things in mind when I designed the TriBlade, but nothing specific
    • I wanted·an ultra flexible pcb design to experiment with·lots of things
    • I wanted to use multiple props because I saw that as a cheap way to do various things
    • I wanted a prop (#2) with fast external memory, so SRAM & Flash & microSD, minimum chip count
    • I wanted a general purpose prop (#1) with VGA, TV, KBD, Mouse and I added SRAM for possible video buffering
    • I wanted an I/O prop (#3) with uncommitted I/O
    • I wanted a USB PropPlug on board
    • I wanted onboard power
    • I wanted to be able to build only the sections required
    • I wanted it to be through hole for hobbyists to assemble but the microSD and FT232RL are only available in smt
    What did I learn....
    • I have found that 512KB SRAM ($3) is adequate for most things
    • No latches for speed
    • microSD is ideal for mass memory.
    • The pcb size·was too·large (approx 7"x3")·so it was too expensive. I did not cover my·monetary·cost.
    • PCB cost over A$800 for 20. With the current·exchange rate, the pcb actually cost me US$35.
    • I did not explain the various build options very well leading to misunderstandings
    • We now have ZiCog and CPM
    • We have PropDos·plus lots of extensions are WIP
    • Ross's Catalina runs on TriBlade but hopefully we can·coax it to live in 512KB·plus uSD
    • I am·extremely pleased with it's design
    • It's design·has not been fully exploited yet
    • Never designed to make a profit
    • Simple design
    • Minimum components (always my objective)
    • Functional self-contained circuits
    • In future, smaller pcb but not too small to cause cost issues
    • Minimise external connections to keep it cheap (they are expensive)
    • My biggest problem is purchasing components -·shipping cost to Australia - adds 50% to my·parts cost.
    Some other things I have learnt over the years...
    • Hindsight ALWAYS prevails
    • Your time is ultimately cheap (free if a hobby as it is for me)
    • Money spent·is expensive
    • Never lose your enthusiasm
    • Always work within your limits
    • Understand your limitations. I understand mine very well, so I always get someone to do what I cannot.
    • Some things you can learn, some you cannot. e.g. 50% of the population can never be programmers because they do not possess a logical mind. But then we cannot do other things.
    Some final comments...
    • Don't waste your time with DRAM. Unfortunately, it is not a usable solution for the Prop 1 which is a real shame. That was what made the Z80 a winner!
    • Be extremely careful of pcb designs
      • Proper decoupling capacitors (the prop is quite critical)
      • Proper ground and power·planes
      • Loading - lots of designs are likely to not work as expected
      • Keep it simple and not too small
    · Home of the MultiBladeProps: TriBlade,·RamBlade, RetroBlade,·TwinBlade,·SixBlade, website
    · Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80) , MoCog (6809)
    edited 2009-10-01 21:46
    Thanks for your words. The super prop design was 8 layers to allow for proper sheilding of traces and to also allow for proper bibass and extremely low emi. That is one of the reasons there is so many bipass caps. i did not just bipass at power pins like many but also at every point i needed to allow current to change planes.
    I have scrapped the dip40 prop compliant form factor and have come up with a much better design. it is not as well shielded as the super prop but in theory that should not be a problem(theory and reality not always the same). I now have 1Gbit RAM design on 4 layer board for $120. More info on new design soon.
    edited 2009-10-01 23:05
    as for some of your other questions my personal goal is to get a DVI connector running and be able to make a high quality digital picture frame.
  • heaterheater Posts: 3,370
    edited 2009-10-01 23:12
    I hate to throw cold water around because I think the Prop could do with a variety of external RAM expansion designs to suit different applications. But I have to say adding a huge pile of RAM to a Prop is like trying to paint a room through the key hole in the door. Its bound to be awkward, painful and slow. The bigger the RAM (room) the more it is going to feel that way.
    1) It will be slow compared to other processors with proper buses. The bigger the RAM the worse this will seem. Applications that need that much space could also probably do with the bandwidth.
    2) It will be more expensive in terms of CPLD or other glue logic.
    3) It will eat up the Prop pins. Which in turn means most of the COGs become unusable as they have no I/O.
    This all means one may as well have used a traditional single CPU chip in the first place.
    As Cluso has described, his TriBlade has one Prop in almost normal Demo Board configuration, another Prop for I/O with most pins free, and another Prop dedicated to RAM and SD with almost no pins free. Well looking at it, the I/O prop is great for driving hardware gadgets, the Demo Board set up is great for some video, keyboard, sound etc. BUT that Prop dedicated to RAM could just as well be a traditional ARM or something for about the same price and would run stuff faster.
    As it stands I love it because I can use the same simple Spin development tool on all three Props on the board and, well, ZiCog is a Prop thing but I think you can see what I mean.
    With all this in mind I'd like to think about going the other way. A small RAM, 512K max, operated though an 8 bit multiplexed bus with a couple of control lines. Some ultra simple cheap glue logic to help it along. Yes I know that will be bit slower but we've already accepted that.
    With this we get to keep as many free pins as possible. Therefore we have COGs that can be used. We can still use the Prop for what it was designed for, driving external gizmos using a brilliantly simple development environment.
    edited 2009-10-01 23:37
    You should have at least 1x 0.1uF X7R, preferably 2+, and 1x 4.7uF (preferably 10uF) tantalum capacitors on the underside of the prop and particularly at the power pins on the crystal side. This is absolutely required for overclocking. I would suggest no IC under the prop. Place a ground trace around your xtal traces which should be as short as possible and as thick as possible. I am aiming to run 120MHz on a new design and hoping that I may actually get close to 140MHz under test.
    edited 2009-10-02 01:52
    heater said...
    Wow! What a simile [noparse]:)[/noparse] Too bad it is so true.
    The huge performance hits incurred by XMM methods are just too much for me. That's why over the last few months I've been chasing "scalable" distributed multi processing (SDMP) which is something the Propeller should be good at doing with the right code in it's native languages, would mean doing big/fast things, would be slowed only by data/messages instead of instructions after startup, won't need gobs of PCB for prototypes, and will not be limited to LED flashers and other such nonsense. I like a lot what the Infini-Prop PCB can do for SDMP (except unused space).
    edited 2009-10-02 02:09
    my new memboard is back to almost my original design. no on board prop so it can be used with any processor though I will be using it with the prop and hope that others will also.
    as for my infa prop I am glad you think it will be useful. if you get a panel of pcbs made up would love to see them in action. Not sure what you mean by unused space. I did have to dedicate a fair bit of space to power traces to allow for large scale off single power supply but i kept that almost entirely under the connectors. Yes it is no where near as dense as my prop galore or your octo prop but the prop galore was expensive and your octoprop has problems of its own. I welcome suggestions for improvement on that.
    edited 2009-10-02 02:51
    When it fails to function I'll believe you. Until then, it's a fine software development platform.
    edited 2009-10-02 02:54
    i doubt your octo prop will fail unless you abuse it. problems with it are stuff like:
    *3d design more susceptible to damage do to droping or impact
    *not feasible for large scale production
    these are not problems in a lab. I think it is a great development platform.
