To heck with the P2, I want the 64-IO P1 - Page 2 — Parallax Forums
2»
  • shanghai_foolshanghai_fool Posts: 149
    edited 2009-10-01 00:40
    I also started the "glue" route but decided a second Prop to only drive 24 servos and a couple of digital output pins would be simpler. Of course it only uses 2 cogs which is a waste but was much simpler than a half dozen additional decoder/driver chips.
  • edited 2009-10-01 01:27
    Commodore's 1541·disk drive only had 2K of RAM and they managed a way to have several·disk drives sharing a bus and each·drive listened to the bus.· I'm sure the patents have long been expired but I think the answer is to have a bus and an input / output scheme.··The 1541 drive·would listen and only use the bus when commanded to talk.· It is what I would do.· You could have two pins devoted to the bus and they would operate different devices on the bus.
    (Edited to clarify)
    Post Edited (Chuckz) : 10/1/2009 3:33:11 AM GMT
  • VIRANDVIRAND Posts: 656
    edited 2009-10-01 06:35
    Serial I/O... if you don't need the speed to go "up to eleven" then two wires is enough to control everything.
    (There was once a rock band that thought "10" wasn't loud enough, so they got knobs that went up to eleven.)
  • heaterheater Posts: 3,370
    edited 2009-10-01 06:48
    VIRAND: You mean the parody rock band "Spinal Tap". You can see the knobs that go to 11 here www.spinaltap.com/
    Over the years they went from "parody" to serious reality. But then in the rock/pop world I find it hard to tell the difference quite often anyway.
    edited 2009-10-01 07:43
    Hy heater,
    i did not know that the picture on 2:18 of this video is an insider like "42".
    LOL-ROFL. Here you can see what happens if you screw the knob to eleven
    best regards
    Stefan
  • dMajodMajo Posts: 862
    edited 2009-10-01 07:48
    Mike Green said...
    dMajo,
    heater is absolutely correct. CMP and SUB are the same instruction with different default settings of WR / NR. They set the flags the same.
    CMP_Z: D=S········· SUB_Z: D-S=0
    CMP_C: D<S········· SUB_C: overflow
    It not seems to me that the two instructions sets the flags the same way, or am I wrong?
    @All
    If the IO timing is not critical, they are not used directly in code (eg. as pointers, byte/word values); than an I2C IO expander can do the job. Beside the traditional solutions [url=http://www.nxp.com/#/pip/pip=[pip=PCA9672_2]|pp=[t=pip,i=PCA9672_2]]PCA9672[/url]/[url=http://www.nxp.com/#/pip/pip=[pip=PCA9673_1]|pp=[t=pip,i=PCA9673_1]|]3[/url]/[url=http://www.nxp.com/#/pip/pip=[pip=PCA9674_PCA9674A_5]|pp=[t=pip,i=PCA9674_PCA9674A_5]]4[/url]/[url=http://www.nxp.com/#/pip/pip=[pip=PCA9675_1]|pp=[t=pip,i=PCA9675_1]]5[/url] there is also the [url=http://www.nxp.com/#/pip/pip=[pip=PCA9698_2]|pp=[t=pip,i=PCA9698_2]]PCA9698[/url](40 I/O) and the Cypress CY8C9520A/40A/60A (20/40/60 IO with programable state retention between power/reset cycles and hardware pwm).
    Quiet sure (because of the prop's boot nature) there is a I2C driver available in nearly every program so it is enough to attach these ICs on the eeprom's I2C bus
    PEDIT: Also TI TCA6424 (24 IOs) is nice
    · Propeller Object Exchange (last Publications / Updates);·· Vaati's custom search
    Post Edited (dMajo) : 10/1/2009 10:22:55 AM GMT
    edited 2009-10-01 08:00
    dMajo,
    When D == S, D - S == 0. When D < S, D - S results in an unsigned overflow (underflow). So the conditions really are the same.
    edited 2009-10-01 09:40
    obviously, sorry my fault. I have stopped to the manual description without looking from the math point of view
  • hinvhinv Posts: 1,272
    edited 2010-10-08 12:48
    Has there been any progress or even effort in the last year on this?
    Doug
  • AleAle Posts: 2,363
    edited 2010-10-08 23:10
    The C1541 Bus is "sort of" a I2C bus, you can have more than one device and it will answer when commanded... you can even have I2C at 1 MHz or break the standard a bit and rise the frequency even more... :). No need to think of a new protocol...
  • Capt. QuirkCapt. Quirk Posts: 872
    edited 2010-10-09 22:41
    This is a bit of a shock, I thought the 64 pin PropI debut would coincide with the new industrial division.
    edited 2010-10-15 07:59
    Yeah, I had hoped they were moving ahead on it. Last I heard IIRC Beau was going to look into fixing the verification software issues, but that was moons ago. Maybe after the shuttle for Prop II is sent off Beau will look into it. Looking back, I think they would have done well in getting MUL and MULS working (4 clock) and maybe ONES and ENC, but I really don't know what they are, and then the 64 I/O pins and call that a Propeller 2. It could be in the same low power technology, and would provide a LOT more calculation power with a real multiplier. With 64 pins(mostly for external memory) and a multiplier would make graphics really rock! Of course, there is a lot of wiz-bang stuff like texturing in the P2 in the works, but I have been anxious. I may be annoying on this subject, but I REALLY do appreciate what parallax does.
    Doug
  • LeonLeon Posts: 7,620
    edited 2010-10-15 08:09
    I seem to remember that they had given up on it, because of problems with their software tools.
    edited 2010-10-15 08:34
    As long as it has more cogs, that's the key. Double the number is good. Ten times more is better. I'll take a cut in speed if required to accomplish it.
  • Bobb FwedBobb Fwed Posts: 1,119
    edited 2010-10-15 08:52
    Man I would love a 64 IO Propeller.
    I have a project that uses 62 IOs, and 10 cogs. If I combined the project into one propeller, I could combine 3 of the cogs. I have to run on batteries at times, so a single propeller (and less cogs) would mean less power, and even if the 64 IO propeller were double the cost, it would be cheaper than my current setup because there are less BOM parts for assembly.
    edited 2010-10-15 09:04
    Humanoido,
    Multiplying the number of COGs by 10 has the effect of dividing the access speed to shared HUB RAM by 10. Some would say this is not a good outcome.
    As the number of COGs goes up overall performance can go down. In the limit there is a infinite number of COGs that have to wait an infinite amount of time for any HUB access. Overall performance drops to zero!
    Where the "sweet spot" is re the number of CPU's sharing RAM is, is a matter of debate.
    A while back Chip did pose the question here "more COGs or more RAM for Prop II" I think the majority were speaking up for more RAM with the above thoughts in mind.
  • BigFootBigFoot Posts: 259
    edited 2010-10-15 11:12
    What we really need is a Prop1 that has allot more ram. We have
    to continually switch programs from the SD card.
    We use a couple 16 bit, I2C I/O chips for our low speed devices,
    they only cost $1.20 each.
    edited 2010-10-15 16:17
    Can these be connected in parallel with the boot eeprom, or do I have to have another line for chip select?
