who said: "No matter how thin you slice it, it is still baloney" ?
I read it somewhere but I do not remember who said it, why or where I read it. But I cannot put it out of my head...
The phrase may not be 100% accurate in its wording but on its meaning if I understand it correctly, english is not my mother language.
thanks!
Visit some of my articles at Propeller Wiki:
MATH on the propeller propeller.wikispaces.com/MATH
pPropQL: propeller.wikispaces.com/pPropQL
pPropQL020: propeller.wikispaces.com/pPropQL020
OMU for the pPropQL/020 propeller.wikispaces.com/OMU
Post Edited (Ale) : 9/29/2009 9:32:01 AM GMT
thanks!
In any case, it doesn't sound like the quote of a single person. It sounds like something many people say every day, with variations. It's what we call a "colloquialism." So if you feel the need to quote it, just start out by saying, "Like the old saying goes That doesn't change the fact that it is still baloney....
At least that is my American mid-western WonderBread-raised take on this.
I think that the phrase you're looking for here is "No matter how thin you slice it, it's still baloney". As ElectricAye said, it's not really any person's quote, but rather a common saying. Of course someone must have said it first, but I doubt that we know who that someone was (unless it's one of the many that originated with Shakespeare, and of course even then we're not sure who really said it).
EAye: it was boloney
It means something along the lines: it does not matter how you decorate a pig because it is still a pig. I guess.
btw: I think I read it in the quotes at IMDB but I am not sure...
Thanks!!
This quote shows in the log files of the Gaussian 03 group of programs. (Soft to do ab-initio calculations on chemical structures).
Smith may merely have been repeating a common expression.
· -- Carl, nn5i@arrl.net
Carl,
I am not impressed. If you were able to Google that in less than 60 seconds, it is only because you stand on the shoulders of giants. Didn't it ever occur to you that all of us who have slaved for hours and hours on Google trying to answer Ale's question have caused the correct search result to rise to the top of Google's search ranking? Your claim to victory is an empty one. So I am throwing down the gauntlet here: Google me a cheap and easy way to paint a straight line in the corner of a room where a wavy wall meets a wavy wall, and I'll reconsider your status.
Watching the world pass me by, one photon at a time.
get a rolling chair the same height you want to draw the line and tape your paint brush to it.
as long as the floor is not wavy this will work and costs nothing assuming you already have the chair. If you don't have a chair you can get a cheap lazer level at walmart for $14
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
Rich H
The Servo Boss, a 12 channel servo tester kit from Gadget Gangster.
Alas.
Post Edited (Carl Hayes) : 9/29/2009 3:56:50 PM GMT
C'mon Carl,
I said "a cheap and easy way to paint a straight line" not project one. It's one thing to project the geometry, it's quite another to paint it. I've tried several devices that are supposed to paint straight lines, make an easy job of trimming, etc. And I've talked to dozens of people on how to do it: so far everyone agrees it's impossible. As for "crinkum-crankum" or whatever, I've never heard that term. The quarter round idea doesn't sound bad, but then I end up with a wavy quarter round instead of a wavy paint line. Carl, can you stand a little higher on Newton there? maybe on your tippy toes or step on up to Einstein's ear? The wife wants different walls painted in different colors and the end result looks non-Newtonian.
laser levels can be used to draw vertical lines also. you then just need to trace it.
If the desired line is vertical, a plumb-bob on a string, with a lamp to cast its shadow on the wall, will serve as a nice guide.
If the desired line is horizontal, a piece of transparent hose with water in it can be used to make a true orizontal.· Hold up both ends, and the water always comes to the same height in the hose at both ends.· Make a mark on the wall at the desired height.· Have a helper move one end of the hose up and down to keep the water exactly on the mark while you move around with the other end to mark the same height at various places on the wall.· Use these marks as a guide for placing masking tape.
Where wall meets wall is vertical (sorta). Where ceiling meets wall is somewhat horizontal.
Carl, your string theory sounds good, and I thank you for your interest, but I'm afraid that you'll encounter a penumbral sort of situation with that. Even lasers give you a diffractive headache.
As for masking tape, there is a special place in hell for the marketing department of all those companies that sell that sort of tape, blue tape, etc. It really just doesn't work. You get dendrites of paint seeping under it no matter how hard you try to press it down. And then, unless you employ a razor blade and infinite patience to cut it free, it will rip off parts of your paint job when you remove it later on. 3M has made tons of money off the stuff, but everyone to whom I've talked (who has actually used the stuff) agrees it's a lie. One thing I've noticed when it comes to gadgets: when you see lots and lots of solutions to a single problem, you can bet that none of them works very well. And so it seems to be with painting trim and getting the lines "straight".
C'mon Carl, your 60 seconds is almost up!
I have only one personal experience with large scale painting, but I helped my dad paint his boat. We used the green masking tape that comes in a plastic bin, and it worked out very well. There was very little seeping, and no pulling of paint when removing the tape. We pulled the tape off parallel to the tape the is still on the surface (as opposed to perpendicular). A note to make here is that the surface was glossy painted fiberglass.
If paint seeps under the edges of your masking tape, either you didn't press it down adequately, or (more likely) you're spraying too wet an initial coat.· Work on your spray technique.· Spray a mist coat, then a fairly dry coat, then several thin coats, with some drying time in between.
Carl Hayes thanks for pointing out my spelling sucks.
Hmmmm. You are the third person to speak of this mythical green tape. I have heard it can do wondrous things - like actually work. Rumor is that it has some kind of gel adhesive that prevents dendrites, etc. A worker at Home Depot told me that it is the only thing that actually works but couldn't remember the name of it but to beware of knock-offs since it tends to be expensive. Do you happen to remember where you got it?
@ Carl, gosh I hope you aren't mad at me for joking around.
so now I'm beginning to believe in green tape. If the seers of the Sandbox have verified it's existence, it must be more than mere legend.
thanks you guys,
Mark
Did I miss something here ? [noparse]:green:[/noparse]
About two months ago I discovered flourescent orange duct tape, which is pretty close to the Holy Grail for rocketeer supplies.
www.lowes.com/lowes/lkn?action=productDetail&productId=309070-56131-187516&lpage=none
But why do they call it Frog Tape? Oh no- Please don't tell me they grind up frog tongues to make it sticky. Say it ain't so!
