Printing Fails
I can't get my code to print. I always get an error message saying: List index out of bounds (0).
I downloaded the beta version of SXB and it behaves the same way.
marshall edgell
marshall edgell
SX/B is a compiler and has nothing at all to do with printing. The IDE does the printing. What version of the IDE are you using?
PeterM
Try upgrading to the latest. I'm also using Vista.
Did you upgrade to the 3.3.0 release yet to see if it solves your printing problem?
PeterM
marshall
Regards
marshall
Did you upgrade the SX-Key software or just the SXB compiler? From your post it looks like you just installed SXB compiler. The new SX-Key software can be found here:
http://www.parallax.com/tabid/460/Default.aspx
Vista is a pain with selecting which program to use. I think I just deleted the 3.2.92 version of SX-Key, file folder and all.
Shawn Lowe
When all else fails.....procrastinate!
Thanks bunches.
marshall
