Printing Fails — Parallax Forums
Printing Fails
edgellmhedgellmh Posts: 85
edited 2009-09-26 20:54 in General Discussion
I can't get my code to print. I always get an error message saying: List index out of bounds (0).
I downloaded the beta version of SXB and it behaves the same way.
marshall edgell
  • PJMontyPJMonty Posts: 983
    edited 2009-09-14 17:43
    Marshall,
    SX/B is a compiler and has nothing at all to do with printing. The IDE does the printing. What version of the IDE are you using?
    PeterM
  • T&E EngineerT&E Engineer Posts: 1,396
    edited 2009-09-14 19:23
    The same thing happened to me yesterday using 2.92H and SX/B 2.00.30 BETA. I selected some code and then went to Print the selected code from the FILE, PRINT, SELECTION and got the same message. I had to copy the selected code and paste into Notepad and then printed the entire notepad message with the code.
  • ChetChet Posts: 150
    edited 2009-09-14 23:42
    I have had that problem for over a year already and have not found an answer. It does it on both XP SP3 computers as well as in windows 2000. (2.92X and SX/B 2.00.XX)
    edited 2009-09-15 01:04
    Tonight I upgraded to the latest software (3.3.0) and using SX/B 2.00.30 BETA and it works fine now with no error.
    Try upgrading to the latest. I'm also using Vista.
    edited 2009-09-23 17:56
    Chet and edgellmh,
    Did you upgrade to the 3.3.0 release yet to see if it solves your printing problem?
    PeterM
  • edgellmhedgellmh Posts: 85
    edited 2009-09-24 17:03
    I am having trouble getting SX/B 2.00.3 to work. I have downloaded it and overwritten the existing SXB.exe file with the new one. I then moved an example.sxb file to that directory and double clicked it. I had to tell the machine what program to use. When I told it to use either SXB.exe or SXKey.exe (v3.2.92) the code loads on a black window and then disappears.
    marshall
    edited 2009-09-24 18:58
    Peter, I am "on the road for the next couple of weeks. I will try it when I get back home.
    Regards
    edited 2009-09-26 13:29
    I loaded SXB 2.00.3 successfully on a second computer but the printing problem remains exactly as before.
    marshall
  • Shawn LoweShawn Lowe Posts: 635
    edited 2009-09-26 15:24
    Edgellmh-
    Did you upgrade the SX-Key software or just the SXB compiler? From your post it looks like you just installed SXB compiler. The new SX-Key software can be found here:
    http://www.parallax.com/tabid/460/Default.aspx
    Vista is a pain with selecting which program to use. I think I just deleted the 3.2.92 version of SX-Key, file folder and all.
    Shawn Lowe
    When all else fails.....procrastinate!
    Okay! That solved the print problem.
    Thanks bunches.
    marshall
