RFDigital 2.4Ghz modules for $15, too good to be true?
WBA Consulting
I am looking at RFDigital's 2.4Ghz modules for a project and was wondering if anyone has any feedback?
2.4 GHz RF Module with built in RFDP 8 Application Protocol
RFD21733 With onboard antenna
RFD21735 For use with external antenna
The low cost and ease of use is very inviting, but is it too good to be true?
PDF Spec Sheet
http://www.rfdigital.com/pdf/RFDP8.RF.Modules.Manual.pdf
Andrew Williams
WBA Consulting
Special Olympics Polar Bear Plunge, Mar 20, 2010
PDF Spec Sheet
Andrew Williams
WBA Consulting
Will it do WIFI?
____________________$WMc%____________
The Truth is out there············································ BoogerWoods, FL. USA
RFDigital does have WiFi 802.11 modules for $79.95, but the datasheet says preliminary, so I am uncertain if they are released to production.
Andrew Williams
WBA Consulting
Tom Sisk
http://www.siskconsult.com
