S-Video circuit. — Parallax Forums
S-Video circuit.
potatoheadpotatohead Posts: 10,267
edited 2009-09-22 20:26 in Propeller 1
This has been mentioned off and on.
Has anyone done this successfully? What circuit did you use?
Chat in real time with other Propellerheads on IRC #propeller @ freenode.net
  • charleyshfcharleyshf Posts: 165
    edited 2009-09-19 03:21
    Take a look at this link here . It's for·a S-Video out circuit.
    edited 2009-09-19 04:31
    Thanks!
    Looks to me like this is pretty easy. The data sheet shows the chroma can be either on the baseband (start + 1 pin), or on the broadcast audio pin (start + 3).
    Both use the same resistor too. A demo board will show the same baseband image either way, as this resistor is wired the same on both pins.
    S-Video then is really all about setting the VCFG bits, and that (start + 3) pin wired apart from the other three.
    edited 2009-09-19 06:10
    Your very welcome. I've been gathering any information I can on the propeller, i'm new to the prop, but not PBasic. I was looking for the same circuit today [noparse]:)[/noparse]
  • ericballericball Posts: 774
    Just be aware there will be some differences between S-Video and composite. The big one is no super-saturated colors when using lum 0 & 7. Normal colors may also have lower saturation depending on whether the TV uses colorburst or sync for AGC and the size of the chroma resistor vs the luma network (if it uses sync).
    The big bonus with S-Video is your luma changes will not cause color artifacts and the luma bandwidth is not limitted to 7.16MHz (455 pixels per line). Chroma is still bandwidth limitted though.
    Composite NTSC sprite driver: Forum
    NTSC & PAL driver templates: ObEx Forum
    OnePinTVText driver: ObEx Forum
