S-Video circuit.
potatohead
This has been mentioned off and on.
Has anyone done this successfully? What circuit did you use?
Chat in real time with other Propellerheads on IRC #propeller @ freenode.net
Safety Tip: Life is as good as YOU think it is!
Looks to me like this is pretty easy. The data sheet shows the chroma can be either on the baseband (start + 1 pin), or on the broadcast audio pin (start + 3).
Both use the same resistor too. A demo board will show the same baseband image either way, as this resistor is wired the same on both pins.
S-Video then is really all about setting the VCFG bits, and that (start + 3) pin wired apart from the other three.
The big bonus with S-Video is your luma changes will not cause color artifacts and the luma bandwidth is not limitted to 7.16MHz (455 pixels per line). Chroma is still bandwidth limitted though.
Composite NTSC sprite driver: Forum
NTSC & PAL driver templates: ObEx Forum
OnePinTVText driver: ObEx Forum
