Bluetooth research - seeking opinions.
I am looking into using Bluetooth technology to implement reliable short-range remote control network. It appears that they use different “profiles’ to communicate between two devices – point to point.
The spec range of 100 meters is OK, but not perfect.
Is there a way to add a custom profile?
I would like to provide redundancy using sort of multipath transmission by tandeming thru another Bluetooth device.
Also I have not found specification for maximum of independent point to pint devices running within the specified range.
Thanks for reading.
Thanks for reading.
Bluetooth sucks,.......Go with WIFI.
You'll be glad you did.
_____________$WMc%_____________
The Truth is out there············································ BoogerWoods, FL. USA
