POLL: What speed are you running?
Oldbitcollector (Jeff)
Some of the more recent video drivers have provided the opportunity to extended capabilities
at higher speeds. I'm curious what speeds people are running their Propellers these days.
Since polling doesn't work on this forum, I've created a quick xtal POLL.
POLL: What speed is your Propeller running at?
: View Results
OBC
New to the Propeller?
OBC
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
160MHz?
Really?
What is the core crystal speed and multiplier you are using as I have done some tests with differing crystals and pll modes and have not got near 160MHz yet.
I've found that the Prop is stable to around 110 MHz @ 3V3 with some extra caps around the supply pins but have had to increase the core voltage to get it to go any faster.
I know Sapieha has had 120MHz (15MHz x 8) for a few months now but I can't get that stable at 3V3 and certain application choke more easily than others (where PASM flags are used extensively)
I've also tried a direct clock source from a 133MHz 3V3 oscillator with no success unless we up the core voltage.
Coley
PropGFX - The home of the Hybrid Development System and PropGFX Lite
I am only doing 80 at moment and attempting to get a 12 something crystal working.
8MHz + PLL4X == 32MHz
The 8MHz because that's what I can get the cheapest. And 4X because it is the slowest possible option that still allows me to use all my objects correctly.
With the 8MHz XTAL, if I bump up the voltage to 3.6V and keep the whole thing cool (cool for room temperature anyway: 65F or lower -- I guess it may not work for all Props), I can run it at 128MHz too! I have no application for that, but others may.
April, 2008: when I discovered the answers to all my micro-computational-botherations!
Thanks Gang!
OBC
· Home of the MultiBladeProps: TriBlade,·RamBlade, RetroBlade,·TwinBlade,·SixBlade, website
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80) , MoCog (6809)
96 Mhz HYBRID
soon, 100 Mhz to be tested on both.
I see in the poll, over half the props reported run at 80. IMHO, since 80Mhz is the reference design speed, feature function breakdowns should take that into account. Best form is probably to make sure baseline functions operate nicely at 80, then provide simple options for speeds over that.
Chat in real time with other Propellerheads on IRC #propeller @ freenode.net
DogP
In Yours POLL table You dont have frequencies ... I run.
15MHz PLLx8. I run it more that 5 month reliable without any problem.
But only on Triblade and USB version of Parallax ProtoBoard with extra Tantalums instaled from them.
And some extra caps instaled by me. All my tests are on standard Voltages and in room temp. -25-28C
Have ben run some tests on biger frequencies to but with some errors. I look on results for at see why.
But at now I'm are busy with other things that speed tests must wait
For every stupid question there is at least one intelligent answer.
Don't guess - ask instead.
If you don't ask you won't know.
If your gonna construct something, make it·as simple as·possible yet as versatile as posible.
Sapieha
Post Edited (Sapieha) : 9/15/2009 4:44:11 PM GMT
--Steve
Propeller Tools
- Propalyzer: Propeller PC Logic Analyzer
- BMA: An on-chip PASM Debugger
- SPUD: Spin Source Level Debugger
Post Edited (jazzed) : 9/15/2009 3:51:53 PM GMT6.250xtals
"Where am I? Where am I going? Why am I in a handbasket?"
I expected 5Mhz/80Mhz to be the leader. After all, everyone gets this crystal out of the box.
What I didn't expect was to see the 6.25 so widely used. Even more than the Hydra.
Neat stuff so far.. (Results Link in the top thread)
OBC
I only voted once each for 5MHz and 6.250MHz btw, even though I have many instances of both running here.
Please use mikronauts _at_ gmail _dot_ com to contact me off-forum, my PM is almost totally full
Morpheus & Mem+dual Prop SBC w/ 512KB kit $119.95, 2MB memory IO board kit $89.95, both kits $189.95
www.mikronauts.com - my site 6.250MHz custom Crystals for running Propellers at 100MHz
Las - Large model assembler for the Propeller Largos - a feature full nano operating system for the Propeller
I'm still poking along at 5Mhz/80Mhz...
Whit+
other than that I left it on all night running LED blinkers and it is working but at 80 Mhz I also found that anything over 5.8 volts on the wounded propstick and it gets burning hot
I install 0.1 mfd and 10 mfd caps at 3 locations on my boards as per Saphea.
The only error I get is when I forget to take account of the higher frequency in the PLL multiplier expression. This is my pilot error...
JMH
Post Edited (James Michael Huselton) : 9/26/2009 3:32:58 AM GMT
12MHz PLL8X (PLL16X didn't work) and 14.3MHz PLL8X along with the 4.43,8.86 and 17.4 trio to see if the PAL chroma could be improved (didn't help much).
The people that answer this question will mostly the ones that use the the non standard frequencies, 90% probably use the given 5x16.
Only using 40 pin DIPs and always heavily decoupled, with the power pins cross coupled under the chip (I wish they would un-cross them).
Style and grace : Nil point
6.5536MHz XTAL and 16*PLL.
Regular 3.3v supply. I added the optional optional capacitors on the back side of the board. Don't know if it really needs them.
I just want to see how much I can get to see where the limits apply, but remember, there are possible variations in the chips themselves.
To all that not understand ned of decoplings Capacitors I have only one question "Look on PC motherboard and answer me if all caps around and bottom on CPU is only for decoration?"
Regards
Christoffer J
Sapieha
frequencies like 6.444 or 5.588 . I thought the consensus was it was a waste since the clock had to be an evenly divided?
Guys also what value decoupling caps is everyone using?
Post Edited (mikediv) : 9/26/2009 8:09:32 PM GMT
With Sapieha's discovery I would almost certainly be willing to use 15MHz ( x 8 = 120MHz ) for commercial product to the hobby market, and would have no qualms at all in using 6.25MHz ( x 16 = 100MHz ) for a more mainstream commercial product.
The 50% gain for a chip-total of 240MIPS at 15MHz over 160MIPS at 5MHz is too sweet to let pass by, but maybe that's just me
My other stuff is running standard@ 5MHz. I have one more 6.25MHz xtal to play with. Now...what to put it into?
Jim
'Necessity is the mother of invention'
'Those who can, do.Those who can’t, teach.'
'Convince a man against his will, he's of the same opinion still.'
