auto-off to save battery charge — Parallax Forums
allniteallnite Posts: 2
edited 2009-09-15 15:06 in Propeller 1
i would like the propellor to turn the circuit off to save battery life. I would like to turn the circuit on using a momentary contact switch, then to turn off the circuit with a signal from the controller. I believe this "auto-off" ability should be a common problem, but i haven't been able to find any information on the web! any help is greatly appreciated!
    edited 2009-09-14 01:02
    There are several such circuits that have been posted in the past. I don't have a link. You'll just have to browse the Propeller forum's threads. It was a year or so ago.
    Make sure to try the Google search engine (search.parallax.com) with a variety of keywords.
  • TimmooreTimmoore Posts: 1,031
    edited 2009-09-14 01:43
    I dont have the links but I did save a couple of circuits from the threads. If you want a re-built circuit pololu sell one http://www.pololu.com/catalog/product/750
    Post Edited (Timmoore) : 9/14/2009 1:48:58 AM GMT
    1305 x 669 - 120K
    849 x 863 - 89K
    edited 2009-09-14 03:24
    Both of those circuits are from my original drawings ...
    The first circuit "poweroff.gif" is an original concept for the Propeller where the power "on" latency needed to be accounted for.
    Reference:http://forums.parallax.com/showthread.php?p=730612
    The second circuit "poweroffswitch.gif" is an improved version over the first, and designed to operate under a lower input voltage.
    Reference:http://forums.parallax.com/showthread.php?p=812900
    Beau Schwabe
    IC Layout Engineer
  • allniteallnite Posts: 2
    edited 2009-09-15 15:05
    Thank you for the drawings! This is exactly what I was looking for. I will try them and let you know how it goes.
    It bewilders me that this is not a more popular problem.
    many of the people here do not worry about power savings. evident by the fact most use linear regulators.
    propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
    Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
    Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
