auto-off to save battery charge
i would like the propellor to turn the circuit off to save battery life. I would like to turn the circuit on using a momentary contact switch, then to turn off the circuit with a signal from the controller. I believe this "auto-off" ability should be a common problem, but i haven't been able to find any information on the web! any help is greatly appreciated!
Make sure to try the Google search engine (search.parallax.com) with a variety of keywords.
Post Edited (Timmoore) : 9/14/2009 1:48:58 AM GMT
The first circuit "poweroff.gif" is an original concept for the Propeller where the power "on" latency needed to be accounted for.
Reference:http://forums.parallax.com/showthread.php?p=730612
The second circuit "poweroffswitch.gif" is an improved version over the first, and designed to operate under a lower input voltage.
Reference:http://forums.parallax.com/showthread.php?p=812900
Beau Schwabe
IC Layout Engineer
It bewilders me that this is not a more popular problem.
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
