Make noise while moving
Is there any way to have a boe-bot make noise while moving? Can you make constant noise while it's running, as opposed to just beep-move-beep-move? And if you can, can you make it a pattern of frequencies. So like
FREQOUT 4, 100, 2000
FREQOUT 4, 100, 3000
FREQOUT 4, 100, 4000
And have it repeat that while moving?
Yes, but you need either a ServoPal or a SoundPal.
To run smoothly, servos need a stream of pulses at 50 times a second. Playing a sequence of sounds will delay those pulses. The ServoPal will send the stream of pulses while the Basic Stamp is doing other things - like playing sounds or checking sensors. The SoundPal works the same way, the BS2 can move on to other things while it plays the sounds.
Rich H
The Servo Boss, a 12 channel servo tester kit from Gadget Gangster.
· -- Carl, nn5i@arrl.net
