Cost = Real cheep but good = not fast...Need PCB Board made...Need feed back P — Parallax Forums
sam_sam_samsam_sam_sam Posts: 2,286
edited 2009-09-14 05:29 in General Discussion
Can any one help
Here is the board that I want to have made
··Thanks for any·idea.gif·that you may have and all of your time finding them smile.gif
Sam
Post Edited (sam_sam_sam) : 9/13/2009 1:21:36 PM GMT
    edited 2009-09-13 14:21
    How many do you need. Gold phoenix is cheap and high quality.
    propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
    Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
    Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
    edited 2009-09-13 21:48
    mctriva
    How you get these files that Gold Phoenix··are asking for Thank You for the link to that site
    ······························ Gerber274X+NC drill files·
    ·Dose the Express PBC program or that software dose not have this as part of there sotf ware
    Sam
    edited 2009-09-13 22:39
    Is your .PCB file for ExpressPCB? If so, this is one of the problems you face. They've got you locked in to their proprietary file format so that only they can provide your boards. I've never used them (and never will), so I don't know if they will convert your file to Gerbers for a fee or not.
    edited 2009-09-13 22:57
    yes you need a program like eagle that will output gerber to use any of the other pcb fab houses.
    have attached cam files for eagle
    ExpressPCB will supply you gerber at a fee. Last time I had to do that, it was $75 on a 4 layer board. Not sure if the fee changes depending on number of layers, etc. This is one reason why I personally dis-like ExpressPCB. Once you start with them, you are stuck with them. I recommend that you look into Eagle or DipTrace.
    Andrew Williams
    WBA Consulting
