Has any one program a PIC16F690 Micro Controller before Need Feed Back Please — Parallax Forums
sam_sam_samsam_sam_sam Posts: 2,286
edited 2009-09-13 19:27 in General Discussion
What Micro Controller that Parallax· sells that will = the PIC16F690· This is my first choice
Or a Real Cheep way to Program the PIC16F690 This is my second choice
Can Any One help
Here is the code that I want to use
··Thanks for any·idea.gif·that you may have and all of your time finding them smile.gif
Sam
Post Edited (sam_sam_sam) : 9/13/2009 1:31:58 PM GMT
    edited 2009-09-13 13:27
    The direct answer to your question is that there is no microcontroller that Parallax sells that is equal to the PIC16F690. On the other hand, it's a pretty meaningless question because it depends on what tasks you need to accomplish. The PIC16F690, like many of Microchip's microcontrollers, has a lot of functional units ... timers, UARTs, USARTs, ADCs, on-chip data EEPROM, on-chip flash program memory, on-chip SRAM. Very few applications need all that stuff (although some do). What functions do you need for this project? Parallax's SX and Propeller microcontrollers can provide some of those functions, but not all of them. They can also provide other functions that the PIC16F690 can't provide. So again, what do you need?
    edited 2009-09-13 13:32
    Mike Green
    Thanks for for your reply the code is post below in the first post
    Thank you for any help that you can give me
    I am not sure what is need
    Sam
    edited 2009-09-13 13:38
    You posted a program with no explanation (it would have helped). I assume that's something that is written for the PIC16F690 that you'd like to duplicate with a Parallax microcontroller.
    You've included no explanation of the program (it would have helped), but it looks like it manages a couple of 7-segment display digits and a relay and it reads one or two channels of analog data including the setting of a pot. It uses virtually none of the PIC16F690 functional units, just a channel or two of the ADC.
    The SX could certainly handle this application. The Stamps could probably handle it, but they're more expensive than a plain SX. A Propeller could handle it easily, but it would also be more expensive than an SX and mostly unused.
    Please do not post these open-ended questions unless you provide some explanation. It's impossible to give you a good answer without more information. Please provide some additional information in your original question. If you're honestly just curious about something, say so. If some project you're working on made you curious, say so and give a little information about what got you thinking.
    Post Edited (Mike Green) : 9/13/2009 1:46:36 PM GMT
  • LeonLeon Posts: 7,620
    edited 2009-09-13 14:17
    I've used the 16F690, it's a very nice chip. The $35 Microchip PICkit 2 will program it, or you could build your own serial port programmer for about $6. I use the Microchip ICD 2. Using an SX chip or a Propeller for that application will cost a lot more than using the PIC, as a external ADC will be needed, and the PIC is a very cheap device. The software will also need to be rewritten.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
    Post Edited (Leon) : 9/13/2009 2:42:56 PM GMT
    edited 2009-09-13 15:05
    For this application, it looks like you would not need an external ADC if you used an SX or Propeller since you're either measuring a pot's value or a relatively slowly changing voltage with 8-bit resolution.
    I agree, the PIC16F690 is a nice chip. I've also used the PICkit2 to program and experiment with it.
    edited 2009-09-13 15:52
    Mike Green
    I was asking this as an open end question
    I will take note of this for the next time I ask a question·like this··smile.gif
    Thanks for every one input to this· question
    I did take alook at this
    http://www.microchipdirect.com/productsearch.aspx?Keywords=DV164120
    Sam
    Post Edited (sam_sam_sam) : 9/13/2009 9:34:54 PM GMT
    If you want to get into pic programming this is a good start. www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName=en023805
    - Stephen
