Has any one program a PIC16F690 Micro Controller before Need Feed Back Please
What Micro Controller that Parallax· sells that will = the PIC16F690· This is my first choice
Or a Real Cheep way to Program the PIC16F690 This is my second choice
Can Any One help
Here is the code that I want to use
··Thanks for any·
·that you may have and all of your time finding them
Sam
Post Edited (sam_sam_sam) : 9/13/2009 1:31:58 PM GMT
Can Any One help
··Thanks for any·
Sam
Thanks for for your reply the code is post below in the first post
Thank you for any help that you can give me
I am not sure what is need
··Thanks for any·
Sam
You've included no explanation of the program (it would have helped), but it looks like it manages a couple of 7-segment display digits and a relay and it reads one or two channels of analog data including the setting of a pot. It uses virtually none of the PIC16F690 functional units, just a channel or two of the ADC.
The SX could certainly handle this application. The Stamps could probably handle it, but they're more expensive than a plain SX. A Propeller could handle it easily, but it would also be more expensive than an SX and mostly unused.
Please do not post these open-ended questions unless you provide some explanation. It's impossible to give you a good answer without more information. Please provide some additional information in your original question. If you're honestly just curious about something, say so. If some project you're working on made you curious, say so and give a little information about what got you thinking.
Post Edited (Mike Green) : 9/13/2009 1:46:36 PM GMT
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Post Edited (Leon) : 9/13/2009 2:42:56 PM GMT
I agree, the PIC16F690 is a nice chip. I've also used the PICkit2 to program and experiment with it.
I was asking this as an open end question
I will take note of this for the next time I ask a question·like this··
Thanks for every one input to this· question
I did take alook at this
http://www.microchipdirect.com/productsearch.aspx?Keywords=DV164120
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 9/13/2009 9:34:54 PM GMT
- Stephen
