xi xo traces for super prop
For those of you not following my I have been designing an 8mb ram 8mb flash board the same size as dip prop pin for pin compatible with the prop.
There is a request that both xi and xo go to both the prop and the cpld ram controller. My question is could there be any issues running a 5mm trace on top to prop and 40mm trace on bottom to cpld?
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
Do both the XI and XO pins have to go to the CPLD?? XI is the mot sensitive to interferance as it is the input to the OSC, XO is the output and presumably goes to the CPLD clock lines. Some discussions have shown the XI and XO pins of multiple props connected together, I would have thought that just the "master" prop's XO would have gone to the "slave" XI pins.
Style and grace : Nil point
Interfearancd should be a small issue I have ground plane on both sides of trace and also on layer above trace. With data lines running perpendicular where they must cross.
I can place a jumper disconnect between xi and cpld but can't on xo do to space shortage.
However, having said that, we know the prop is sensitive in this area, and the PLL can be killed. What you are doing is not permitted in the data sheet, so you are on your own here. Personally, I would not use this method.
· Home of the MultiBladeProps: TriBlade,·RamBlade, RetroBlade,·TwinBlade,·SixBlade, website
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80) , MoCog (6809)
Anyway the purpose is to avoid the usage of the pll and to feed the prop with a clean frequency from DC to 80/100MHz.
1) In this way the cpld will be always phase alligned with the prop system clock. (The pll, from its nature,·introduces random phase angles, within the clock period if good, but this is still a phase drift)
2) This allows the prop being fed by a high accuracy frequency down to DC(156K) switchable on the fly (also by external events) allowing thus timing accuracy at low speeds and high speed reaction to events accomplishing big power savings.
· Propeller Object Exchange (last Publications / Updates)
