Hyperterminal — Parallax Forums
Hyperterminal
oopoop Posts: 28
edited 2009-09-12 20:04 in General Discussion
Frnd ,
how do we transmit text messages from bs2 to far destination through modem via hyperterminal command .
  • stamptrolstamptrol Posts: 1,731
    edited 2009-09-12 12:18
    First, get two modems that use the Hayes "AT" command set. Virtually all yard-sale modems fall in this area. You'll want a model that can go down to 2400 or 4800 baud. Manuals are online. Google the model you have.
    Plug one modem into a laptop/desktop running Hyperterminal and set the modem to 2400 baud, auto-answer. Save the settings to the modem's non-volatile memory. Take this modem and connect it to the Stamp.
    Plug the other modem into the laptop/desktop and set it to 2400 baud. Send the dialing command "ATDTnnnnnnn,ENTER". Where nnnnnnn is the Stamp modem's telco number.
    You will have to write a Stamp program using the SERIN and SEROUT commands to properly interpret the data as it comes in.
    Give us more detail and we can probably provide more specific help.
    Cheers,
    Tom Sisk
    http://www.siskconsult.com
  • oopoop Posts: 28
    edited 2009-09-12 16:05
    frnd ,
    the commands as at+cmgf=1 and at+cmgs="phone no." not are used in this function !
    So, you really want to send a SMS message using a cell phone?
    Its always good etiquette to provide enough information so someone willing to spend time with you doesn't have to play "20 questions".
    Good luck.
    Tom Sisk
