Hyperterminal
Frnd ,
how do we transmit text messages from bs2 to far destination through modem via hyperterminal command .
Plug one modem into a laptop/desktop running Hyperterminal and set the modem to 2400 baud, auto-answer. Save the settings to the modem's non-volatile memory. Take this modem and connect it to the Stamp.
Plug the other modem into the laptop/desktop and set it to 2400 baud. Send the dialing command "ATDTnnnnnnn,ENTER". Where nnnnnnn is the Stamp modem's telco number.
You will have to write a Stamp program using the SERIN and SEROUT commands to properly interpret the data as it comes in.
Give us more detail and we can probably provide more specific help.
Cheers,
Tom Sisk
http://www.siskconsult.com
the commands as at+cmgf=1 and at+cmgs="phone no." not are used in this function !
Its always good etiquette to provide enough information so someone willing to spend time with you doesn't have to play "20 questions".
Good luck.
Tom Sisk
