FSRW: She's So Unusual - Page 7 — Parallax Forums
1457910
  • heaterheater Posts: 3,370
    edited 2009-09-12 01:45
    lonesock
    You need to add backslashes to your calls to sdfat methods in serial_terminal.spin else the aborts don't get caught. For example:
    term.dec( \sdfat.mount_explicit(term#sd_DO, term#sd_CLK, term#sd_DI, term#sd_CS) )
    This why it hangs.
    With this is in place I get:
    mount returned -1000
    for my dead card. Which I guess is ERR_CARD_BUSY_TIMEOUT
    Post Edited (heater) : 9/12/2009 1:53:51 AM GMT
    edited 2009-09-12 02:54
    The code I posted last night on TriBlade can start displaying (using spin and FDX) the sector information from any fixed start sector onwards. Perhaps this may make the basis of some tests for you heater.
    · Home of the MultiBladeProps: TriBlade,·RamBlade, RetroBlade,·TwinBlade,·SixBlade, website
    · Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80) , MoCog (6809)
    edited 2009-09-16 07:30
    lonesock: I am trying to put your code mb_spi.spin into the TriBlade.
    I use the pins to the SD card on a bus so I must release them after use, just as DO must be forced into tristate. Looking at the pasm code, I can reset DIRA to all inputs after I use your code to force DO tristate. I need to also add setting DIRA outputs for each r & w command. (It is possible to leave -CS an output but DO,DI & CLK must be made inputs.)
    Will the following work? Any delay required after the dira pins are set to outputs, particularly the -CS pin?
    I declare a long setdira
    setdira LONG 0 'store the output pin mask
    I change the SPI_engine_entry instruction "RDLONG DIRA,PAR" to
    RDLONG setdira,PAR 'save the output pin mask
    MOV DIRA,setdira 'set the output pins
    I add the following line immediately after start_mb_read and start_mb_write
    I add the following line immediately before release_DO_ret
    MOV DIRA,#0 'make all inputs
    Any other comments??
  • lonesocklonesock Posts: 917
    edited 2009-09-16 16:30
    I'm not sure about the mb_spi code (as that was a slightly older incarnation), but the mb_rawb_spi code should do what you want already. There is a line in the PASM release_DO subroutine that you need to uncomment (tip: search for your user name [noparse][[/noparse]8^). mb_small_spi should also work if you uncomment the line. It is smaller but slower. Both of these versions implement a read-ahead / write-behind strategy that should help performance while not costing you much more than a little extra PASM code (the buffered data is in cog RAM). I think the mb_spi _could_ be made to work...the problem was not in releasing the data lines, but in making sure they are outputs again as needed.
    Jonathan
    lonesock
    Piranha are people too.
    edited 2009-09-17 03:07
    Thanks for your reply Jonathan.
    Postedit: Aha! I see where to uncomment the line to tristate the outputs - I missed that before smile.gif
    I cannot use read ahead or write behind because I use the SD pins as a bus to the SRAM. They must be released before I can continue as I need to retake control with another pasm program. So I need a routine/command that releases the lines and a routine/command that retakes the lines so that I can do a block read/write.
    Post Edited (Cluso99) : 9/17/2009 3:30:00 AM GMT
    edited 2009-09-17 16:46
    The RA/WB stuff is inside a state machine. It will only perform read-ahead if you are reading, and write-behind if you are writing. As soon as you give the release command, it will finish what it is doing, release the pins, and return control to you (i.e. "release" is a blocking call). Then absolutely nothing happens until you request another read or write, so it should be safe for your application.
    Jonathan
    lonesock
    edited 2009-09-18 06:26
    lonesock: Here is some code·that I cannot get working once I release the pins, although release is not the problem as I can comment this out.
    Perhaps I am missing something in trying to drive the mb_rawb_spi.spin directly, passing it a block number and buffer and expecting a read/write to work.
    Basically this is the sequence
    • sd.mount_explicit(spiDO,spiClk,spiDI,spiCS)
    • sd.popen(filenamestr,"r")
    • sd.datablock············································ 'works correctly
    • sd.get_filesize·········································· 'works correctly, but not relevant - can be omitted
    • sd.stopSDCard··········································'calls sdspi.release· but not the cause of failure (can be omitted)
    • sd.readSDCard(drive_base[noparse][[/noparse]17], @buff, 256)·· 'calls sdspi.readblock(xxx,@buff) <-- fails to return from this call!
    v122 runs on fsrwFemto (and modified)
    v123 runs with fsrw23 (and modified)
    ZIBOOT.COM is the SD file, although it can be any file for the test.
    edited 2009-09-18 16:42
    I haven't had time to look at your code yet, sorry. One possibility I forgot to mention, though, is that my low-level code requires that your buffer be long-aligned.
    Jonathan
    lonesock
    edited 2009-09-19 03:46
    Thanks Jonathan. Yes it's long aligned and nothing is being returned so I suspect it is hanging waiting on the cog.
  • SamMishalSamMishal Posts: 468
    edited 2009-09-19 06:17
    Hi All,
    I have just tried the FSRW2.3 test using a
    Propeller Demo Board + uController.Com SD card adapter, with a 1GB SD card
    with no maker...cheap from MicroCenter. I used Parallax Serial Terminal with FullDuplexSerial.
    Worked GREAT and GOOD speeds. here are the results.....
    But before that a comment on the Parallax Serial Terminal (I used it) inability to
    cut text in its window to the clipboard.....IT CAN.....use CTRL+C...see this posting.
    That is how I got the text data below.
    Here are my results.....Thanks Tomas Rokicki and Jonathan Dummer for this great Object.
    Notice my great speeds....good for a cheapy card.
    Size: 1GB....formatted for FAT16 and 64K clusters
    Type: Unknown...cheapy bought from MicroCenter
    Test: Succeeded all throughout
           Clock: 80_000_000 ClusterSize: 65536 ClusterCount: 15622
           Raw write 3968 kB in 2331 ms at 1702 kB/s
           Raw read 3968 kB in 2371 ms at 1673 kB/s
           fsrw pwrite 4064 kB in 3620 ms at 1122 kB/s
           fsrw pread 4064 kB in 3191 ms at 1273 kB/s
           FSRW pputc 63 kB in 2087 ms at 30 kB/s
           FSRW pgetc 63 kB in 1836 ms at 34 kB/s
           All done!
    Problems: I had no problems whatsoever.
    Here are results with FAT16 with 32K clusters....not much slower
           Clock: 80000000 ClusterSize: 32768 ClusterCount: 31241
           Raw write 3968 kB in 2335 ms at 1699 kB/s
           fsrw pwrite 4064 kB in 3891 ms at 1044 kB/s
           fsrw pread 4064 kB in 3203 ms at 1268 kB/s
           FSRW pputc 63 kB in 2089 ms at 30 kB/s
           FSRW pgetc 63 kB in 1837 ms at 34 kB/s
           All done!
    Regards
    Samuel
    Post Edited (SamMishal) : 9/19/2009 6:41:20 AM GMT
  • Jim FouchJim Fouch Posts: 395
    edited 2009-09-21 15:50
    I got the SEEK method working, just not sure how to post the code.
    It basically works by keeping track of the first sector when the file is opened. When the SEEK method is called, it checks to see if the desired position is before or after the current position in the file. If it's before, then it resets to the first location and quickly follows the chain to the desired position. If its after, then in quickly folows the chain to the desired position.
    I have done limited testing with a 300K file and it works perfectly. I have only tested·for 'r' mode. I have no idea
    Do I just add it as an attachment here, or does it need to go through source forge?
    I mad ethe following changes in the fsrw.spin file...
    Add this to your VAR section
    Long InitialCluster ' First Cluster of file.
    ·Added the following code to the popen method...
          if (i == 11 and 0 == (byte[noparse][[/noparse]s][noparse][[/noparse]$0b] & $18)) ' this always returns
             fclust := brword(s+$1a)
             InitialCluster := fclust ' Used later for seek function   <<<<<<<<------ Only added this line, others are for position reference
    I added these two methods...
    Pub Seek(Position)| r, t
      ' Added to allow the quick seeking to a specific location in the file
      ' The file first has to be open in Read Mode
      ' You can't seek past the end of the file
       ' First check to see if we want to seek to a location lower in the current
       ' location.
       If Position==floc ' We must already be at the proper location
          Return
       if Position<floc
          ' We need to move backwards, it's just easier to start at the begining
          ' of the file and scan forward.
          if (direntry)
             pflush
          bufat := 0
          bufend := 0
          floc := 0
          writelink := 0
          direntry := 0
          fclust := InitialCluster
          frem := (SECTORSIZE << clustershift) <# (filesize)
       else
          ' We're moving forward so simply scan forward
          Position := Position - floc
       repeat while (Position > 0)
          if (bufat => bufend)
             t := _SeekForward ' Read more Data from Media
             if (t =< 0)
                return
          t := (bufend - bufat) <# (Position) '  Calcilate how many bytes to read and limit to Count
          bufat += t
          r += t
          Position -= t
       Return
    pri _SeekForward : r
    '   This sub is only called by the Seek method.
    '   It simulates the reading of bytes without actualy reading any bytes
       if (floc => filesize)
          return -1
       if (frem == 0)
          fclust := nextcluster
          frem := (SECTORSIZE << clustershift) <# (filesize - floc)
       'sdspi.readblock(datablock, @buf)
       r := SECTORSIZE
       if (floc + r => filesize)
          r := filesize - floc
       floc += r
       frem -= r
       bufat := 0
       bufend := r
       ' return r (default return)
    Jim Fouch
    FOUCH SOFTWARE
  • rokickirokicki Posts: 1,000
    edited 2009-09-21 16:29
    Thanks! While this technique will work, and is suitable for the moment, absolutely, I was hoping
    to do it in a slightly different way.
    The technique I was going to use was to take the existing code I have for seeking within a cluster
    and use that, and only use *this* technique if the seek position was outside the cluster.
    I need to just sit down and write the code.
    I'm not sure I see how it reads the first block after the seek, in addition, so I'll have to study
    the code some more.
    In any case, if this works, that's great! I need now to decide if I'm going to test and integrate
    what you've sent, or just write it the way I was planning to.
    Maybe this is the incentive I need to sit down and write this and get it out the door.
    edited 2009-09-21 17:10
    Rokicki,
    I agree this is probably not the best way. It was justa quick stab at it as I don't fully understand the rest of the driver.
    Let me know if you need help testing with your approach.
    Jim Fouch
    FOUCH SOFTWARE
    edited 2009-09-21 17:42
    Thanks! Depending on work demands I hope to spend some time playing tonight.
  • KyeKye Posts: 2,200
    edited 2009-09-22 01:05
    This is how I got the seek method working for my code. If it applies to you then it may be helpful. I believe my method waste as little time as possible seeking.
      if(cardFileInUseFlag)
        position := ((position <# (previousSize - 1)) #> 0)
        ' If in current sector then done.
        if((currentByte >> 9) <> (position >> 9))
          ' If not in current sector then flush out working sector in in write mode.
          if(filereadWriteFlag)
            ifnot(readWriteCurrentSector(true))
              return false
          ' If in current cluster then go to that cluster.
          if(((currentByte >> 9) / sectorsPerCluster) <> ((position >> 9) / sectorsPerCluster))
            ' In the cluster is in front of us start from current position, or go back to the begining of the cluster chain.
            if(position < currentByte)
              currentByte := 0
              currentCluster := currentFile
            ' Seek until you reach teh cluster from the start of teh chain.
            repeat until(((currentByte >> 9) / sectorsPerCluster) == ((position >> 9) / sectorsPerCluster))
              currentByte += (sectorsPerCluster << 9)
              result := (readFATBlock(currentCluster) & readFATEntry(currentCluster))
              ' Parse FAT code for errors.
              if((result =< 1) or ((not(FATType)) and (result => $FFF0)) or (FATType and (result => $0FFFFFF0)))
                return false
              ' Set new position.
              currentCluster := result
          ' Set switch flag for reading in new sector if you went to a new sector.
          result := true
        ' Set new position.
        currentByte := position
        ' Read in new sector.
        if(result)
          ifnot(readWriteCurrentSector(false))
            return false
        ' Success.
        return true
    Sorry about the lack of comments. For anyone who knows what is happening behind the scenes in a FAT file system driver the code should be pretty readable however.
    Nyamekye,
    Post Edited (Kye) : 9/22/2009 1:12:15 AM GMT
  • RaymanRayman Posts: 15,899
    edited 2009-11-15 14:36
    How fast do you guys think I can read a 131kB file over and over again?
    Going to try showing a 6-bit photo directly from the SD card...
    Is doing seek(0) the best way to restart reading the file from the beginning?
    My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
  • BaggersBaggers Posts: 3,019
    edited 2009-11-15 14:46
    Rayman, if you only need 131KB, can you store what sectors each bit is on, then just read those sectors directly, that way you won't need to seek.
    edited 2009-11-15 19:40
    Pretty fast. Seek(0) should be really fast. And the actual reading should be fast if
    you pread(); the bigger buffer the better.
    If you're talking at screen rates, though, no, I don't think it's going to be *that* fast,
    primarily due to Spin overhead.
    Rayman said...
    edited 2009-11-15 23:47
    I read files and get the physical sector address on the card. Later I use that to do a low level sector(s) read. Works providing the sectors are contiguous. (see ZiCog and TriBlade threads).
    edited 2009-11-16 01:50
    Well, I'm just trying the dumb way with seek(0) and pread and guess what...· It works!
    It's not perfect yet, and there is a somewhat noticeable flicker, and the screen position isn't entirely stable, but this is pretty amazing, I think...
    Here's a photo of the screen cyclically reading from SD.· The vertical position is off, but you get the idea...
    1496 x 1122 - 695K
    6bit.JPG 694.8K
    edited 2009-11-16 01:57
    Am I abusing my SD card? There's no lifetime limits on reading, right?
    edited 2009-11-16 02:47
    Reads should be fine. And even writes would take quite a while to wear out a larger card with the wearleveling they have.
    Jim Fouch
    FOUCH SOFTWARE
    edited 2009-11-16 16:33
    Yeah, a seek(0) followed by pread is really not that different from just grabbing the sector numbers (especially if you are using 32K clusters).
    Glad it works!
    The main limiter on the speed is probably the memory copy (but that's done a long at a time so should be pretty fast).
    edited 2009-11-24 06:10
    lonesock: Many thanks Jonathan. The bugfix works·jumpin.gif· Sorry to take so long to test it. While I have not given it a rigerous workout, I have seen no errors on booting CPM and doing a "ls" (like a dir). BTW I am using 6MHz xtal for 96MHz operation smilewinkgrin.gif
    FYI: Posted are the 2 mods that I do (disable readahead and enable the tri-stating). Also the mods for Femto call compatibility (although I will be able to remove this, it may be useful to post it here)
    Post Edited (Cluso99) : 11/24/2009 6:23:52 AM GMT
  • MagIO2MagIO2 Posts: 2,243
    edited 2009-11-24 22:16
    Is there a chance to get SD card running with FSWR24 on a breadboard?
    SD card works fine with a FSWR 1.7, but when I switch to 24 it does not pass the boot-block-test. And in fact it reads $d0 $02 instead of the right values. But the boot sector is fine on the card. I had very long wires, so I shortened them. I replaced the 20kOhm resistors proposed in the old FSWR with 10kOhm - but it did not help.
    edited 2009-11-24 22:41
    Try a 1uF Tantalum cap across the power pins on the SD socket. If this does not work then your lines are still too long.
    edited 2009-11-24 22:52
    Try reducing your clock frequency way down; if it works at 10MHz but fails at 80MHz, it's the wires
    or capacitance or something. If it fails at 10MHz, then it's something else.
    Please report back.
    -tom
    edited 2009-11-24 23:04
    I have a 10MHz crystal, so I changed to PLL4x and FSWR24 works then. As I said it already worked with FSWR1.7 which is half the speed of FSWR24, so I expected the breadboard setup being the problem.
    Guess now time has come where I need some kind of board with SD card ;o)
    edited 2009-11-24 23:16
    Heh, that's great news (that it works at PLL4x). Have you tried all the low-level drivers supplied? One of the
    "slower" ones may be just the ticket.
    Would it be asking too much to see a picture of your setup? I am using a breadboard for my tests and it
    works fine there, but the wires are short.
    edited 2009-11-25 01:07
    One of the SD recomendations is for a bulk capacitor close to the card power supply pins. That is why I suggested this and it could manifest by looking like it is too fast.
